It is currently Fri Jul 04, 2025 11:16 pm
PostPosted: Tue Nov 01, 2016 3:16 pm
Is there enough room to mount Universal under dash unit in the middle of the dash?
Concerned about shifter clearance.
Any advantage to getting the heater option? Not sure if the Vintage product uses engine heat or electric coils.
Do you have to fabricate a mounting plate for the compressor?
A picture of the mounted Vintage unit would be great.
Thanks so much.
PostPosted: Thu Nov 03, 2016 11:29 pm
I don't think anyone here has installed a Vintage Air system on their LUV. And if you do, I wouldn't worry about the heat option. The stock heater warms that little cab very well.
PostPosted: Mon Nov 07, 2016 6:03 am
I have seen it done but you lose the glove compartment.
PostPosted: Mon Nov 07, 2016 8:25 am
The plastic glove box or the under dash metal tray? This is my 5th LUV and the only one that didn't have the tray removed
PostPosted: Mon Sep 11, 2017 1:48 pm
The original factory A/C replaced the parcel shelf under the glove box, I would imagine the Vintage Air system would as well.
