It is currently Fri Jun 26, 2026 4:09 am
 Post subject: Stock Valve size G180
PostPosted: Fri Aug 19, 2016 6:43 pm
I have tried my but off to find the stock valve size on a G180 head. Can anyone enlighten me???
PostPosted: Fri Aug 19, 2016 10:51 pm
I know it is hete somewhere... I have discuased it with one of the older experts
There are different sizes at some point i believe... Its late now but i can try to look tomorrow
PostPosted: Fri Aug 19, 2016 11:46 pm
Starting in 1980 the intake diameter went down from 42.4mm(1.67") to 40.4mm(1.59"), the exhaust stayed at 34mm(1.34"). The G200Z 1.9 engines also used the same size valves as the 1980-on G180Z.
PostPosted: Sat Aug 20, 2016 7:23 am
Thank you for responding so fast. You don't happen to know the length?
PostPosted: Sat Aug 20, 2016 8:05 am
4.3543"/110.6mm intake
4.301"/109.25mm exhaust
Stem diameter is 8mm
Overall length is nearly identical to the 2.3 & 2.6 engine valves, stems are all 8mm, which leads me to believe that if there's enough material to machine for the larger valve seats you could install up to the 44mm/37mm 2.6 engine valves. In fact someone at ozgemini has most likely done it.
PostPosted: Sat Aug 20, 2016 9:31 am
90% sure someone on ozgemini with a turbo g180 has 4ze1 valves i think there was some piston clearancing required tho...
PostPosted: Sat Aug 20, 2016 12:39 pm
How's that luv of your running? I know you were putting a 4.3 in and before you finished I had burned my self out on mine.
PostPosted: Sat Aug 20, 2016 1:31 pm
Doing great minus the cheap ebay hei distributor failing on me. Dies occasionally. Punch the coil on top and it fires right up.. Chinese pos. Tried soldering all external connections to no avail its internally f'd.
What are you planning for yours with the valve sizes?
PostPosted: Tue Oct 04, 2016 7:10 pm
I ordered a Gemini kit a couple weeks ago and they recommended 4zd1 exhaust valves and said the intake may already be as big as the ones on that engine. They are cheap so if anyone knows the intake valves fit let me know so I can get some.
PostPosted: Tue Oct 04, 2016 10:13 pm
Your '79 engine should have the larger intakes, which are the same size as the 4ZD1 engine (42.4mm), but you won't know for sure until you measure. The exhausts are 34mm, 4ZD1s are 36mm. If the outside valve seat dimensions are both the same I see no reason the 4ZD1 valves & seats can't be installed.
