It is currently Wed Feb 18, 2026 11:28 am
Post new topic Reply to topic  [ 37 posts ]  Go to page Previous  1, 2
PostPosted: Thu Feb 11, 2016 6:14 pm
I realize they don't have much power and I'm not gonna be passing a lot of ppl , but changing the gears in the rear end have to help somehow . Has anyone with a stock set up changed the rear end gears and not the tranny and had more highway success ? If the 77 and up had 4.10's would it be smart to buy a parts truck and take the rear end and the front disc brakes , or can I order 4.10 or 3.73 gears for what I have now ?
My first Luv
PostPosted: Thu Feb 11, 2016 6:27 pm
My 72 had the 4.56 gears when I got it and it would barely go 45 before it sounded like it was going to blow. This was with 14" wheels, small block and turbo 350. I tracked down a 3.42 rear carrier out of an 81 pup and then added 235.75.15 tires and it was way better. I could cruise on the freeway but still not happy with the RPMs. The gears set helped a little as did the tall tires. I then swapped to a Ford 9 inch with 3.00 gears and I think it is perfect now. It will still spin the tires at will and cruise at 70. My current tires are 245.60.15.
When these trucks were made the national speed limit was 55 so they are happy at that speed. I have a stock 78 now too and it is what it is. For around town it is fun to drive but long freeway trips are no fun. A VW bus is faster than a stock Luv in my opinion.
PostPosted: Thu Feb 11, 2016 6:42 pm
You're not going to be able to order gears for your rear end anywhere.
A parts truck is always good to have. Front discs are great. Swap the rear end and you'll be cruising a lot happier.
PostPosted: Thu Feb 11, 2016 6:47 pm
Cruising at 3000-3500 rpms isn't awful once you get used to it.
PostPosted: Thu Feb 11, 2016 6:59 pm
oldestisuzuist wrote:
3rdLuvNext2a66MALIBU wrote:
All this talk about gear ratio has me curious to know what mine is.
I have a newer 11k miles Ca stock 1.8 motor & carb w/ smog still hooked up, early 5 spd (rebuilt) trans upgrade & mine seems to scoots down the highway pretty good, when my foot is into it i can reach 100mph 8)... Okay... with a slight down hill :lol: I believe i still have a stock rear end , & running 14 inch tires & my speedometer gauge matches up when i pass by a speed radar sign.
Are there markings on the rear end that confirm what we have or we did we calculate that when it was apart ?
From my earlier reply: "For gasoline powered trucks most manual tranny LUVs & P'ups from '77-'87 came with 4.10 gears." Stock gears in '77 were 4.10s.
Oldestisuzuist
although you may have given me the answer ( & don't get me wrong THANKS ) But it really doesn't answer my question about > "how to identify them by markings or what have they ".
Sometimes the tools (id-markings) are more valuable then the answer....as were still under assumption its the stock rear end in a 39 yr old truck.
PostPosted: Thu Feb 11, 2016 8:34 pm
No way that I know of. Get into those manuals you are selling and see what it says.
PostPosted: Thu Feb 11, 2016 8:50 pm
Oldestisuzuist
There are no markings. You can open it up and count the gears. You can jack one wheel up and turn it 1 full revolution and count the number of revolutions the yoke turns. You can get a tach and a gps speedometer and do a calculation going down the road. I can't think of any other way to identify.
PostPosted: Thu Feb 11, 2016 11:16 pm
Go back & read the entire reply that I took the quote from, it will give you some idea of what trucks had what rear end gears. It also states that there are no identifier tags & that no new gears are available, even gives you the R&P count for each available ratio. When you find a donor then you'll either have to spin a tire & count driveshaft revs or pull the 3rd member & count R&P teeth to confirm the ratio. Don't bother with 4wd trucks, they all had 4.10 gears.
PostPosted: Fri Feb 12, 2016 2:17 am
Also remember: If you jack up one wheel only, the yoke turns will be half speed. Example:---one turn of the wheel causes yoke to turn 2 1/4 turns. Times 2 = a 4:56 ratio. What differentials do.
PostPosted: Sat Feb 13, 2016 11:14 pm
What rpm figures are you looking at around 60 mph? I've been wondering my rear end ratios and I have a 79 2wd.
Yellow 74 LUV. Factory a/c
White 79 LUV. Factory a/c
Tucson, AZ
PostPosted: Sun Feb 14, 2016 8:15 am
4.10 manual
3.73 auto
Either tranny is 1:1 in high gear.
Use something like this http://www.bgsoflex.com/rpmmph.html to calculate rpms or mph.
PostPosted: Wed Feb 17, 2016 3:38 pm
I guess need to slow down when i'm thru skimming post.... Thanks ...Oldestisuzuist
PostPosted: Thu Mar 10, 2016 5:00 pm
I just recent bought a 1977 2wd auto for a parts truck. It has the stock rear end in it , does anyone know what gears it has in it ???
My first Luv
PostPosted: Thu Mar 10, 2016 7:36 pm
PostPosted: Thu Mar 10, 2016 8:34 pm
I want to put it in my 74 2wd 4 speed. Should go right in correct or does the auto/man matter ?
My first Luv
PostPosted: Thu Mar 10, 2016 8:52 pm
Should go right in.
PostPosted: Thu Mar 10, 2016 9:09 pm
Hell yeah thank you 4.10 has to be better than 4.56 lol
My first Luv
