It is currently Sun Jun 07, 2026 2:09 am
 Post subject: Fuel_Sending_Unit
PostPosted: Wed Mar 02, 2016 11:04 pm
this comes up enough to share.....I personally have NOT bought one,.... but it was shared as an option on a fb page.
http://www.partstrain.com/store/details ... 7060B.html
 Post subject: Re: Fuel_Sending_Unit
PostPosted: Thu Mar 03, 2016 1:00 am
The LUV does not use the same ohm range as a standard Chevy, with out knowing what the sender you linked to is on its range it's hard to say if it will work, my guess it's it won't be correct.
PostPosted: Fri Mar 04, 2016 1:36 am
I'm not sure what that ohms range was on this one....( the link is down for maintenance /repairs i guess.)
I didn't recall read Standard Chevy, i did read no compatible w/ fuel cells
I believe i saved it from a Luv page ...darn maybe it was my chevelle page... :lol: too many groups n cars
my notes show the couple i have tested that & that came out of a Luv (assuming their stock) measured were between :
Spare Sending unit ohm range reads :
Empty 15.0 ohms to Full 119.0 ohms ...=/- 5. ohms & the one in my truck read
Empty 25.0 ohms to Full 126.0 ohms ...=/- 5. ohms
& for those reading here's a >> How to test them video ......find others watch a few and learn 8)
https://www.youtube.com/watch?v=yU1BDBZWl8A
Once sending unit is out of the tank ....i took the cover off you see this.
This 1st pic is the range your traveling to get low to high ohms ...when testing
The 2nd picture show my fixed connection see that glob. of shiny solder.. :lol:
PostPosted: Wed Apr 06, 2016 8:57 pm
I guess i had those #'s backwards
163
PostPosted: Tue Jan 17, 2017 3:31 pm
Sorry to bring an old thread back here, but I'm replacing the fuel tank sending unit in my truck, and theres two wires that come from the harness, but only one spade connection on the actual sending unit. Can someone post a picture of the top of the tank for me so i can get an idea on the wiring?
Yellow 74 LUV. Factory a/c
White 79 LUV. Factory a/c
Tucson, AZ
PostPosted: Thu Mar 09, 2017 12:12 am
Did you find what your looking for ? 1 Wire will be a ground and the other goes to the gauge
PostPosted: Tue Mar 14, 2017 11:27 am
I believe that the black wire is the ground and the other wire is the positive that goes to the gauge cluster. Do you just ground the wire to the unit itself or just a chassis ground? I got in a hurry when disassembling the truck and I forgot how it grounds.
Tucson, AZ
PostPosted: Tue Mar 14, 2017 11:54 am
Jacobbarnes1 Depends on what pump your using. my stock pump has rubber grommets on the mount. if you ground it to the unit it may not ground ..But Grounding the wire to mount bolt will ground it to the frame.
PostPosted: Thu Mar 16, 2017 10:28 pm
Thanks for all the help. Much appreciated
Tucson, AZ
PostPosted: Sun Mar 19, 2017 1:38 pm
:signwelcome
Users browsing this forum: Baidu [Spider] and 19 guests
