It is currently Wed May 13, 2026 3:01 pm
 Post subject: How much meat?
PostPosted: Sat Feb 20, 2016 11:28 am
If I was to go with a narrowed 9 inch rear, but not back half my truck, how wide a tire can I get between the frame and body?
What has worked for you?
 Post subject: Re: How much meat?
PostPosted: Sat Feb 20, 2016 12:50 pm
Depends upon where the tire needs to clear. On my truck at the top center of the arch there's 11" between the frame & the fender lip, at the bottom front corner there's 9-1/2", at the bottom rear there's only 9". If the tire diameter is small enough to stay away from the fender corners you could probably tuck 10" top center.
PostPosted: Sat Feb 20, 2016 1:54 pm
if you have a fleetside you can get a 29x10.5 slick under It, If you have a step side if will vary to the type of fender flair is on the fenders so anywhere from a 9 inch wide to a 10.5 slick. On the fleet bed the bed floor ends even with the frame but the stepside carries over about an inch. I had a 29x10.5 on my 76 fleet side and a 9 inch wide slick on why 76 step side. Hot rod has the truck truck now with the second set of fenders on it and I think he has a 29x10.5W on it now.
PostPosted: Sat Feb 20, 2016 3:14 pm
And 29x10.5 is enough to give you plenty of traction at the track? I plan on a built sbc, possibly a powerglide and 9 inch. Hoping to run in the 10's-11's. Just not wanting to back half it if I can get away with it.
PostPosted: Sat Feb 20, 2016 3:37 pm
yep....went 6.20 on a 9inch hooiser slick in the truck in my avatar. That was on the factory luv suspension front and back with factory shocks, no cal-trac's or after market parts. Sbc/glide/9inch/5.00 gear/3200 stall with a 150 shot. I may have a vid somewhere.
PostPosted: Sat Feb 20, 2016 4:07 pm
for the life of me I can't remember how to post from you tube. Get on you tube and go to ct's channel, then to videos then select oldest to new and you will see some of my vids on the yellow luv.
PostPosted: Sat Feb 20, 2016 4:45 pm
PostPosted: Sat Feb 20, 2016 4:48 pm
PostPosted: Sat Feb 20, 2016 4:55 pm
Thanks drummer. what's the secret?
PostPosted: Sat Feb 20, 2016 5:32 pm
Your YouTube video is http://youtu.be/YiQ-h0LwdUM
So you take everything after the last / and put it in between [ youtube] and [/youtube]
It should look like this (without the space)
[ youtube]YiQ-h0LwdUM[/youtube]
PostPosted: Sat Feb 20, 2016 10:07 pm
Thanks for the info. I'm still too financially screwed up to start on this, but I was looking at the truck today and started thinking about it.
PostPosted: Wed Feb 24, 2016 11:21 am
Thats a nice size tire, to fit that you just have your rearend narrowed to
The stock iszuzu rear end?
PostPosted: Wed Feb 24, 2016 11:47 am
That's what I did.
PostPosted: Wed Feb 24, 2016 2:37 pm
What size backspacing ive seen 3.5"-4.5"
PostPosted: Sun Jul 17, 2016 8:43 pm
I have a 28 x 9 on my blue truck and it works good . I have had a 28 x 10.5 true on the blue truck also that should be plenty of tire for a while . Best pass 11.43 this is on a 28 x 9 M/T with a tube.
PostPosted: Sun Jul 17, 2016 10:21 pm
Whats your 60ft ? And nice truck ! Im gonna try for mid 11s with a 26 et street
PostPosted: Sun Jul 17, 2016 10:36 pm
1.58 it only has 3.60 rear gear......street truck
PostPosted: Mon Jul 18, 2016 10:18 pm
Fast truck , mind me asking what the combo is?
PostPosted: Tue Jul 19, 2016 9:23 am
Suspension is stock . 385 sbc, th 350, 9 inch ford 3.60 gear .
PostPosted: Mon Jul 25, 2016 1:42 pm
Do you remember the size rim and backspacing you ran ?
Thank you
