It is currently Fri Jun 19, 2026 4:51 pm
Post new topic Reply to topic  [ 28 posts ]  Go to page 1, 2  Next
 Post subject: canopy compatibility?
PostPosted: Sat Dec 26, 2015 1:59 pm
Has anyone found a canopy/topper from another model of truck that fits the luv bed correctly? Most of the 80s truck beds are about the same size but are there any that line up the same?
Hauling a lot of tools and materials jobsite to jobsite and the rain kind of bites for that
PostPosted: Sat Dec 26, 2015 2:46 pm
I have been trying to find one for quite a while. The bed size is 76x60 which is fairly common but the issue is newer trucks slope forward at the back of the cab. Luvs however are straight up and down on the rear of the cab. This makes fitment issues. When looking at a topper look at the leading edge toward the cab and if it isn't straight it wont fit right. Also there is a website with a list of bed sizes that is helpful. Older mini-trucks were all about the same size too if you see a Datsun or Courier topper.
http://www.truckinamerica.com/toppers/BedSize.htm
PostPosted: Sat Dec 26, 2015 3:22 pm
The locally fabricated aluminum shell I have had for 36 years fits the LUV I bought it for AND the 2003 EC Tacoma I recently acquired, so a topper for a '95-'04 regular bed Tacoma should fit your LUV as long as the front is vertical to match the slope of the cab.
PostPosted: Sat Dec 26, 2015 5:08 pm
Awesome thank you!
Craigslist ad title confirmed size convently well
"MOLDED FIBERGLASS CANOPY FOR TOYOTA TACOMA 60X76"
This style looks vertical at front
http://portland.craigslist.org/mlt/pts/5353300807.html
PostPosted: Sat Dec 26, 2015 9:47 pm
I doubt it will work. I bought a bed cover for a Tacoma, I have to cut it down to fit.
PostPosted: Sat Dec 26, 2015 10:08 pm
I was thinking I will have to make a one off quick release to attach it to the bed rails. Seems like the closest fit so far
How far off was the fitment on the cover?
Gotta find one that works or make one incorporated into a ladder rack myself
PostPosted: Sat Dec 26, 2015 10:23 pm
I forgot, it's been a while since I checked it, several inches each way.
PostPosted: Sat Dec 26, 2015 10:44 pm
Any idea what year it was from?
If both beds are 60x76 it shouldn't be that far off
PostPosted: Sat Dec 26, 2015 11:10 pm
Did yours maybe come from a T100? Those are 77 x 67
I'm seeing 76x61.5 for the Tacoma regular and extended cab I believe these measurements are the topper size so worth may be over bed size slightly, not sure
PostPosted: Sat Dec 26, 2015 11:12 pm
Looks like early yotas were 76x60 too
PostPosted: Sun Dec 27, 2015 8:38 am
On the chart that last column is the degree of the slant at the front of the cab. 2,4 and 10 degrees. That is the issue with fitting a Luv. Mazda seem to be straight at the front. Also for hard bed covers I was told a Nissan Frontier fits a Luv.
PostPosted: Sun Dec 27, 2015 8:56 am
Yeah i was looking at the slant angles whichever company makes those toppers wouldn't work but I have seen a couple that don't match the cab curve. I will have to do some measuring and comparing at picknpull and see what I find . Would be easier than making my own at least.
PostPosted: Sun Dec 27, 2015 11:23 am
Just went and measured mine and it is 60 1/2 wide and 76 3/16 - 76 1/4 long, and 19 7/8 at the highest point above the front bed rail.
May just make my own integrated into the ladder rack I have to make myself anyway. Hopefully that way I can make the whole assembly one piece I can remove fairly easily. Trying to fab a ladder/lumber rack around a Toyota canopy that doesnt fit perfect to begin with may be a pain and probably end up ugly :econfused
Will have to see what may or may not fit
PostPosted: Tue Dec 29, 2015 11:19 pm
Picked up an aluminum one off a 85 toyota pickup, fit my truck better than it fit his, he wasn't sure what it was originally for but it fits my truck perfect will post pics tomorrow
PostPosted: Wed Dec 30, 2015 11:14 am
I am picking one up from a 94 Nissan from a co-worker. I will post some pics when I get it.
PostPosted: Wed Dec 30, 2015 11:39 am
From what I found most early toyota and nissans, and some newer ones have the same bed size as long as the front isn't angled forward.
Universal flat front ones will probably all "fit"
PostPosted: Thu Dec 31, 2015 6:01 pm
My newly acquired aluminum canopy, squared up just right at the back of the bed and doesn't raise my roof line except at the sites where the cab drops off sharply.
It has a very slight angle which makes getting to the front to bolt it down a lot easier but doesn't interfere with fitment
Absolutely perfect width
Still need to remove it and weather strip around the bottom but I had to get it home so I bolted it down
PostPosted: Thu Dec 31, 2015 9:19 pm
Looks good, mini farmtruck style 8)
PostPosted: Thu Dec 31, 2015 10:21 pm
Considerably slower... But yeah
I wish I had the side windows his has, my center side ones open out like rv vent windows with the screw in/out knob. Definitely adds to the sleeper factor, once I get a muffler that ya know, muffles... its just an old v6 work truck..
That mini farm truck looks like a handful to drive!
Biggest plus is the canopy weighs nothing. I would be surprised if it was over 50lbs.
PostPosted: Wed Jan 27, 2016 5:32 pm
It only took 4 years to find it but I finally did. This is a real old school shell that came off a 72 Luv that has been sitting since 1986. It's a little dirty but in good shape otherwise. 8)
Just set in place for now. I need to change out the handle with a new one. Its rusted in place.
