It is currently Sun Jun 28, 2026 12:58 pm
PostPosted: Fri Sep 26, 2014 7:42 pm
Hi, thought I'd post some pictures of my attempt at doing a diesel swap in my Luv. I'm using a 2.2 Isuzu with a custom turbo and a T5 tranny out of a s10.
Edit. Are my pics upside down?
File comment: The engine
File comment: This is the truck
PostPosted: Fri Sep 26, 2014 9:04 pm
Yes they are...
Yes they are...
PostPosted: Fri Sep 26, 2014 9:06 pm
Lol I only posted once...
PostPosted: Sat Sep 27, 2014 6:46 am
What am I doing wrong?
PostPosted: Sat Sep 27, 2014 7:40 am
When I click on one to expand it, it's right-side up. I'm guessing it has something to do with the EXIF metadata that's part of the image file header. And I'm guessing you shot them with a smartphone. Most phones shoot in "portrait" mode by default because the screen is laid out that way. So you have to turn the phone one way or another to shoot in "landscape". The phone senses this, but it apparently got confused.
Some photo editing programs will correct this.
PostPosted: Sun Sep 28, 2014 7:11 pm
Ok I'll try to get some more pictures and hopefully i can get them right side up. The engine is in the drivers side mount fit perfectly but the pass side only caught the bottom half of the mount. The shifter is lined up dead center. The only problem I had is the turbo hit the brake master cylinder I swapped the brake cylinder out of the donor truck.
Would someone have a pic of how the hydraulic clutch is conected to the clutch pedal.
File comment: Custom tranny mount
PostPosted: Sun Sep 28, 2014 7:28 pm
I don't have a picture but I think it's just a pin. In the info section of this site is a parts book, the drawings will be there. All of your pictures are right for me.
PostPosted: Mon Sep 29, 2014 5:39 pm
Interesting manifolds. Did you make them?
What size turbo are you using?
Eric Q.
My build thread.
PostPosted: Mon Sep 29, 2014 7:51 pm
Eric, your question about the vacuum pump (from the other topic) is easily answered here. It's visible in the photo above. It's the belt-driven diaphragm pump between the head and the cone filter.
PostPosted: Tue Sep 30, 2014 11:00 am
The previous owners brother made the manifolds. The turbo is a Garrett GT2052s. It makes about 6 psi @60 mph on flat ground and on a hill at the same speed it will do around 10psi.
PostPosted: Sat Nov 15, 2014 9:21 am
Ok I've made some progress. I got the glow plugs set up,got my water pump rebuilt and on. Things are coming together!! A few more hours of work and I can see if it'll start!!
File comment: Shot of the engine
File comment: Glow plug wiring and fuel filter
PostPosted: Mon Nov 17, 2014 7:44 pm
I'd be interested to know why the intake manifold was replaced.
Tom
PostPosted: Wed Nov 19, 2014 12:46 pm
It was originally n/a so a new intake had to be made for the turbo.
PostPosted: Sat Apr 11, 2015 7:01 pm
Got the truck on the road today. Paint will have to wait till next winter.
PostPosted: Sat Apr 11, 2015 10:18 pm
Nice work.
PostPosted: Fri May 29, 2015 8:35 pm
Got about 600 miles on it and it's running great but I have a fuel leak from the injection pump that I need to fix after I figure out where it's coming from.
Also made a hitch for it.
PostPosted: Sat May 30, 2015 11:05 am
Cool project. About how much time did it take you?
PostPosted: Sat May 30, 2015 11:07 am
I spent a little over a year slowly working on it.
