It is currently Fri Jul 03, 2026 5:01 pm
 Post subject: Engine swap kit/Headers
PostPosted: Mon Dec 29, 2014 12:23 am
I am trying to figure out if the the Ace or Hooker headers will fit my truck as the V8 swap was done on my truck in the late 70's. The original owner of my truck owned a machine shop and fabricated the engine mounts. Can anyone with the ACE or Hooker engine swap kit with headers post some pictures showing engine position with some kind of reference to something that can be measured in a comparison?
PostPosted: Mon Dec 29, 2014 9:57 pm
search beer budget engine swap on here, it has part #
PostPosted: Tue Dec 30, 2014 12:10 am
I'm not worried about part numbers or how to do the conversion. Both companies claim their headers only fit their engine swap kits Since my truck doesn't use either of these brand name parts I would like to use one or the other companies headers because I am not into building headers from scratch. It also doesn't do me any good to buy a set of headers that won't fit when if someone could post a couple of decent pictures of how these parts fit in the truck so I can say oh shit look at that a glass eye in a ducks ass could tell there is no way in hell those factory made off the shelf parts will fit.
PostPosted: Tue Dec 30, 2014 5:22 am
I have no experience with power by ace , but i fabbed my own motor and trans mounts and used both block huggers at first and Hookers later wiith the same set up .
PostPosted: Tue Dec 30, 2014 6:26 am
I had the power by ace mounts and headers on my old one. I don't know where any pics are though. The power by ace mounts bolt to the stock mounting locations. Block hugger headers wouldn't work with those mounts.
If you post a pic of your mounts, someone might be able to tell you what would work.
PostPosted: Tue Dec 30, 2014 8:46 am
PostPosted: Tue Dec 30, 2014 8:47 am
PostPosted: Tue Dec 30, 2014 8:50 am
Sorry to post individual pictures I'm using my phone. Here are a few pictures of how the motor sits. The tape measure is up against the fire wall.
PostPosted: Tue Dec 30, 2014 9:38 am
I can't really see much but it looks like you have factory ram horn manifolds now that are center dump. I would think the block huggers should fit. Your firewall clearance is less than mine though.
PostPosted: Tue Dec 30, 2014 11:07 am
75 V8LUV wrote:
Man i hate glass fuel filters
PostPosted: Tue Dec 30, 2014 12:35 pm
hotrod80 wrote:
Especially on the pressure side.
There are too many variables for me to even post my set up. My engine is set low and back as far as I could, I made my own mounts and was able to use hooker headers. Hookers have one pipe that wraps around the frame, clearance is tight around the torsion bars etc. depending on height it may not fit, it's the same way as front to back clearance.
PostPosted: Tue Dec 30, 2014 1:05 pm
My goal is long tube headers. I don't know if the pictures listed on summits website is an actual picture of the hooker luv specific headers or just some random long tube. I also looked at the headers on the ace website and they look like they might work. I'm not sure the difference between their old style and new style either. I guess worst case I get a header building kit and spend a ton of time making my own.
The glass filter was on it when I got it. Future plans include all new bigger line and better fuel pump. I have had nothing but bad luck so far with this truck and would like to get it where I could at least get a test drive in as I have never driven it yet.
PostPosted: Wed Dec 31, 2014 10:54 am
These are the hooker headers for a luv. Bear in mind my engine is set back 3 inches.
PostPosted: Wed Dec 31, 2014 10:55 am
pass side
PostPosted: Wed Dec 31, 2014 8:04 pm
Frige thanks for the pics. From what you have and what you might be able to figure out by looking at your truck do you think that if your engine was moved forward 3 inches or roughly forward so that the center two exhaust ports on the head were directly in line with the cross member for the front of the torsion bars that those headers would possibly fit?
PostPosted: Thu Jan 01, 2015 8:08 am
I am sure they will fit. I have used the hooker luv truck headers on several different trucks and never used the hooker mounts. The main thing is that they clear the frame and the torsion bars if you use them.
PostPosted: Thu Jan 01, 2015 8:19 am
I like that answer. Ditching the front torsion bars would be nice and maybe in the works way down the road. I have not researched it yet and not 100% sure on how to exactly go about doing it.
PostPosted: Fri Jan 23, 2015 12:39 am
It appears you are actually down and forward in contrast to either the ACE or Hooker kit. Send an email to the tech at Powerbyace.com include some pictures of the custom mounts where they attach to the frame. Are they bolted in or welded.
The difference of the ACE old vs new headers is the #1 tube on the right side has been rerouted, so that the larger GM flywheel and starters can be used.
PostPosted: Sat Oct 17, 2015 9:38 am
Whats up with the square tubing where the shock goes?
PostPosted: Sat Oct 17, 2015 9:56 am
Mock up...
Users browsing this forum: Baidu [Spider] and 21 guests
