It is currently Sun Jul 12, 2026 9:52 pm
 Post subject: Fuel gauge working
PostPosted: Wed Aug 13, 2014 8:28 pm
My black luv truck the fuel gauge always shows empty. Where should I start trouble shooting first?
Gauge to tank or tank to front. I will have remove the driveshaft, then the tank.
 Post subject: Re: Fuel gauge working
PostPosted: Wed Aug 13, 2014 8:43 pm
Ground the wire going to the sending unit. If the fuel gauge goes to full it's the sending unit, if not check for power at the back of the gauge, there is a plug by the frame near the cab/bed. Look at the wiring diagram to determin the color code and ground it there.
PostPosted: Wed Aug 13, 2014 9:49 pm
Mine occasionally shows empty, it's always the connection on top of the tank for the signal wire to the sender, a good wriggle and it's fine again.
PostPosted: Thu Aug 14, 2014 1:18 am
thanks for the info I am having the same problem I must have knocked it loose when I was sanding and painting the frame :oops:
