It is currently Thu Jul 16, 2026 5:53 pm
Post new topic Reply to topic  [ 217 posts ]  Go to page Previous  1 ... 5, 6, 7, 8, 9, 10, 11  Next
 Post subject: Re: my 78 luv build
PostPosted: Fri Jun 06, 2014 12:23 am
very nice! that's awesome. few more steps and it'll be driving
PostPosted: Fri Jun 06, 2014 11:55 am
Yep! Almost got the exhaust finished last night, driver side is done, passenger side just needs to be welded the rest of the way, ran out of gas last night :/ right now its just 2" pipe with glasspacks . Will get upgraded later on and mitered the all the cuts, so no fancy bends, I like the look more over pipe bent with a bender, but it took a lot more time to do.
I'm workin' on it
78 chassis with 75 cab
SBC
PostPosted: Wed Jun 11, 2014 1:34 pm
Question for you guys, which wire coming off the ignition switch do I tap into to run to the distributor? There is 1 black 1 blue, 1 black/white stripe and 2 black/yellow. Right now I've just got a wire from the dizzy straight to the battery, which works for now but when its back on the road I'd like to turn it off with the key
I'm workin' on it
SBC
PostPosted: Thu Jun 12, 2014 3:25 pm
Picked up a throttle cable today and have a chrome 120 amp 1 wire alternator that should be here next week.
I'm workin' on it
SBC
PostPosted: Sun Jun 15, 2014 6:26 pm
Throttle cable bracket, chrome 1 wire 120 amp alternator and 140 gph fuel pump will all be here this week. Going to pick up the intake vacuum t and some tranny fluid this week also. Just need to adjust fpr, finish welding and bolt up exhaust, install everything and ill be able to take it for a quick spin! Still need an electric fan
I'm workin' on it
SBC
PostPosted: Sun Jun 15, 2014 8:29 pm
That thing is looking sweet! Can't wait for more pics! I am looking at doing a v6 or v8 build for my luv, any advice?
1979 LUV
4 spd 4x4
4cyl 1.8L
PostPosted: Sun Jun 15, 2014 9:53 pm
Thanks!! It's always nice to hear that. As for doinga v6 or v8 swap, have a job, have the tools, and acquire all the parts first, then swap everything in a day or 2. This thing wouldnt be anywhere near where it is today if I didn't have all the tools to do it.
I'm workin' on it
SBC
PostPosted: Mon Jun 16, 2014 4:03 pm
Throttle cable setup is done! Kinda ghetto rigged, but it works, and that's all that matters. Will change it later on. Waiting on my fuel pump and alternator. So close to being driveable. I'm so ready to be done and enjoy it. Fan,tranny fluid, run a wire for alternator and it'll be "done"
I'm workin' on it
SBC
PostPosted: Tue Jun 17, 2014 8:15 pm
Oh okay I will do that! Thanks for the advice!
1979 LUV
4 spd 4x4
4cyl 1.8L
PostPosted: Wed Jun 18, 2014 5:37 pm
Installed one of my head units today, along with 4 6" and 2 4" speakers powered by an amplifier. have a 12" sub also but the box wouldnt fit behind the seat. Guess ill make one someday
I'm workin' on it
SBC
PostPosted: Fri Jun 20, 2014 6:49 pm
couple pics. got stuff done today. finished and installed exhaust, installed fuel pump, got the right size belt finally, wired up alternator and bought some more tranny fluid. all that left to do is pour gas in the tank and bolt on bed, adjust the fuel pressure, make sure fluids are good and I can take it for a spin! if there is no leaks or anything.
I'm workin' on it
SBC
PostPosted: Fri Jun 20, 2014 10:01 pm
Fired it up and let it run for a little bit. Fuel preessire regulator is weird and I can't figure it out. So I bypassed it. Have a leaking tranny hose which will be replaced. Thing is loud! And shakes the entire truck haha. Gear drive sounds great as expected :) tomorrow ill pick up the hose, top off the tranny, figure out fpr and fingers crossed take it for a spin
I'm workin' on it
SBC
PostPosted: Sat Jun 21, 2014 12:28 am
http://m.youtube.com/watch?feature=yout ... iYNLfeBI1E. Video from tonight, idle is high, and it sounds a lot better in person
I'm workin' on it
SBC
PostPosted: Sat Jun 21, 2014 6:12 am
Looking good. You are giving me inspiration to get back to work on mine.
PostPosted: Sat Jun 21, 2014 12:15 pm
Thanks! So question for you guys. Which wire do I tap into to run to the hei from the ignition switch so it shuts off with key?
I'm workin' on it
SBC
PostPosted: Sat Jun 21, 2014 1:46 pm
Tranny leak fixed, now I have a coolant leak from the upper radiator hose. Waiting for it to cool down before I tear into that. Also think my temp sending unit is dead. Not moving the gauge, gauge does work. Still need to figure out hei and ignition deal so it shuts off with the key. And wire up the electric choke
I'm workin' on it
SBC
PostPosted: Sat Jun 21, 2014 11:04 pm
Drove it for the first time since august 1st. And with a v8 this time. Just went like maybe 1/4 mile. This thing is a beast! And the high idle matched with worn drum pads, the tires spin on gravel when I put it in gear lol. Monster lights them up like nothing. Did a 1/4 burnout lol. 4 banger was fun but not nearly this much fun :)
I'm workin' on it
SBC
PostPosted: Sun Jun 22, 2014 6:17 am
I used the old wire from my coil to power the hei.
PostPosted: Sun Jun 22, 2014 5:29 pm
Didn't think of that. I deleted those worse though :(
I'm workin' on it
SBC
PostPosted: Sun Jun 22, 2014 6:58 pm
You will need to find key on power then.
