It is currently Thu Jun 11, 2026 11:28 pm
 Post subject: LUV tires
PostPosted: Thu Jan 23, 2014 4:34 pm
What is the largest tire a stock 79 4x4 will take, has stock rims?
 Post subject: Re: LUV tires
PostPosted: Thu Jan 23, 2014 4:58 pm
Welcome back to the forum!
27x8.5r14 is probably as big you can go without lift or fender trimming. I just put 225/70r15 on my truck yesterday with no lift and it fits very well with enough clearance to not rub through suspension travel. That's the same as a 27.5x8.5r15.
You could probably do a 28x8.5r14 with shackles and tightening the torsion bars without clearance issues.
Biggest problem with our trucks are the small wheel wells which forces trimming the fenders or doing body lifts. I personally don't like body lifts but that's the only option if your not wanting to do Solid Axle Swap or hack up fenders.
Interco makes swampers in a 225/?r14 and 27x9.50R14 and 28x8.5r14. Beyond that your left with changing wheels or pizza cutter all terrains at best. I really wanted to keep stock wheels for appearance but finding aggressive tires was either non existent or expensive. I put 15 inch Isuzu trooper wheels and gained a lot more options for tires and picked up a nice set of used tires for $100.
PostPosted: Thu Jan 23, 2014 5:08 pm
Thanks. So 27x8.5r is the same as 225/70r15?
PostPosted: Thu Jan 23, 2014 5:23 pm
I meant to say is 27x8.5r14 the same as 225/70r14?
PostPosted: Thu Jan 23, 2014 6:58 pm
A 27x8.5r14 is about 1/2 inch shorter than a 225/70r15 and 1/2 inch taller than a 225/70r14.
Always remember that each tire brand fluctuates +/- 1/2 inch from the next tire brand. Most brands will post the actual measured height on their website. Check out interco tire co website and you'll see what I mean.
Here's a really good tire size calculator. Play around with it and you will be able to convert tire sizes and compare to find the size you need.
http://www.tacomaworld.com/forum/tireca ... -27-8.5r14
If your willing to do a body lift I've heard that 30s will fit with without issues.
