It is currently Mon Mar 02, 2026 7:46 am
Post new topic Reply to topic  [ 1122 posts ]  Go to page Previous  1 ... 50, 51, 52, 53, 54, 55, 56, 57  Next
 Post subject: Re: LUV II
PostPosted: Sat Sep 14, 2013 3:11 pm
LSX LUV Owner
Needed some more room
PostPosted: Sun Sep 15, 2013 2:39 am
Excellent job on this truck, and also the first one with the 305 700r4 as far as that goes.
PostPosted: Sun Sep 15, 2013 12:24 pm
<--Jealous as usual! :wink:
Off topic, what rims are on your Silverado? Motometal? I need some for mine and there are not many styles I like anymore, but those look good! 8)
PostPosted: Sun Sep 15, 2013 1:11 pm
LSX LUV Owner
Thanks!
20x10 method race wheels. "The standard" is the name I think. The white silverado has the same wheels, but 17x8.5"
PostPosted: Sun Sep 15, 2013 2:10 pm
Thanks! Went to their website and this was one of the first things I seen there. :lol:
PostPosted: Sun Oct 13, 2013 6:38 pm
LSX LUV Owner
Finished up the new dash panel and ac install today. Dad came over and charged the system this morning.
Also cut the hood and instead of dzus fasteners i went with these.. http://www.quik-latch.com/
I still need to do a little cleaning up of my cuts on the hood. Hoping this weekend the tune will be dialed in.
PostPosted: Wed Oct 16, 2013 6:34 pm
Man what a badass truck! I wanna say i first seen a build on s10forum.com? and i dig it! Theres a luv with the same graphics that runs around here once in a blue moon. Keep it up man :D
If the system fucks you. You fuck it back!
PostPosted: Sun Dec 08, 2013 5:13 pm
LSX LUV Owner
Had to notch the frame since i had to lower the back down after i put the bigger tires on the back to keep it sitting like it was. Garage pics like normal.
PostPosted: Sun Dec 29, 2013 8:45 pm
LSX LUV Owner
traded in the ext cab on this 2014 fusion. Nice car.
And finally got the tune finished up on the luv. Been forever since i could do this.
And one more super shitty pic
Hoping to hit the track soon once it opens back up to see what itll do.
PostPosted: Mon Dec 30, 2013 6:18 am
Nice car . Your wife should love it . We just added a 2014 Ford also . Ford builds some nice stuff . Who did the tune for you ? glad to see it running up to par . Did you dyno it ?
PostPosted: Mon Dec 30, 2013 8:02 am
LSX LUV Owner
Yeah they have some nice cars and trucks out. She will miss the truck but loves the car just as much. My buddy Carl has been doing the tune. He works at a plant and works a ton so he can't make it down here very often, but he does it for free so im patient. No dyno yet. I would like to dyno it soon, curious as to what kind of power it makes.
PostPosted: Tue Dec 31, 2013 8:41 pm
LSX LUV Owner
PostPosted: Sun Jan 19, 2014 8:04 pm
Killer build!
(I noticed it was for sale)
Hate to see it go. Hopefully, whoever buys it continues the path.. making it one of the baddest LUV's I have seen :)
Mike
PostPosted: Sun Jan 19, 2014 8:06 pm
LSX LUV Owner
I have zero luck with trannys. :lol: :oops: :roll:
PostPosted: Wed Jan 22, 2014 4:08 am
Wow , trans was just done . 4l60E issues . Next will be 4l80 swap
PostPosted: Wed Jan 22, 2014 9:14 am
LSX LUV Owner
Yes that tranny has maybe 500 miles on it. I think im gonna give him one more go round with rebuilding it. Need to call him and see what he will do. He told me it wouldnt hold up to the new motor, but i know guys with 60e's running more power in heavier vehicles then me that has lasted a bunch of passes and a bunch of street miles.
PostPosted: Wed Jan 22, 2014 12:38 pm
You should build a 65e. That way you have a stouter trans without the excess driveline loss of an 80e. My brother used to own a LS performance shop in DFW and built countless 65e's that'd hold any n/a build. He put a 65e on a c6 that made 495 whp on stock ls2 short block, angle milled stock port ls3 top end and a .635/.635 cam. They then put a 200 shot and it still survived very well. You should definitely look into a 65e and probably a different trans guy cause a 60e should hold a lot better than 500 miles. I assume quite a few of those were tuning miles too. I know a lot of the builds he did were full size trucks and they seemed to hold well on the stock 60e.
Have you had yours dynoed yet? Total weight?
PostPosted: Wed Jan 22, 2014 12:39 pm
Also what brand of fluid are you using?
PostPosted: Wed Jan 22, 2014 2:13 pm
LSX LUV Owner
truck weighs 3050 pounds without me in it.. a 60 and 65 are the same basically, 65e came with a few better parts from factory IIRC but once a 60e is built, and a 65e is built, they are the same.
PostPosted: Wed Jan 22, 2014 6:21 pm
Unless the internals are upgraded to 65e planetary set I would think it'd be inferior but I do see what you mean by once fully built it should all be the same. You should definitely be able to get a built 60e/65e to hold up in a lightweight truck if built properly. Maybe the parts he's installing are just duds. If there's a lemon I usually end up with it. Maybe your having the same problem. Is he going to warranty it?
Users browsing this forum: No registered users and 1 guest
