It is currently Mon Mar 30, 2026 5:43 am
PostPosted: Sun Jul 14, 2013 2:04 pm
My key ignition wont turn the starter. I believe it's because I have a wire missing.
I can arc the contacts with a screwdriver and start the truck, but I'd rather use my key. Haha.
PostPosted: Sun Jul 14, 2013 3:16 pm
The black with white stripe wire activates the starter solenoid. The red one looks like someone added for something. It is on a terminal that only has power when the starter is cranking.
If no crank, check the clutch switch operation.
PostPosted: Sun Jul 14, 2013 3:36 pm
Thanks, egg. Where is the clutch switch located? (1978) I can't find even a mention of it in my Haynes manual.
EDIT/UPDATE: Well, I don't know what I did, but after wiggling some wires (under the dash by the ignition, around the clutch pedal, and so on), the dang thing turned over with the key!
Looks like I may have some electrical projects in my future. :)
And I think I found the clutch switch. Is it the contact switch on the pedal itself?
PostPosted: Sun Jul 14, 2013 4:44 pm
Yes, located on the clutch pedal/arm itself, usually green wire.
