It is currently Fri Feb 06, 2026 5:14 pm
PostPosted: Fri Apr 19, 2013 12:02 pm
Hey Guys
Im looking for the bracket that houses the electronic box for my LUV. Anyone have any idea where i may be able to pick one up. Let me know 8)
***79 Shortie***
PostPosted: Sat Apr 20, 2013 1:53 am
Btown wrote:
Hey Guys
which box are you refering to? the relay box? or the bracket that holds the coil?
PostPosted: Mon Apr 22, 2013 9:58 am
the bracket that holds the coil and the electronic ignition box bolts too
***79 Shortie***
PostPosted: Mon Apr 22, 2013 1:43 pm
you mean the ballast resistor that sits right on top of the coil?
we dont have electronic ignition stock but you can swap it from the later g200
but i do have the bracket without the resistor because i swapped to electronic ignition, where are you located?
PostPosted: Mon Apr 22, 2013 2:58 pm
i have the stock resistor still but i lost the bracket for the module and the one i have is a touch too narrow....i enjoy doing the simple way if i can and i have burned up a box before not having it grounded properly....oops :esurprised
***79 Shortie***
