It is currently Mon May 25, 2026 3:02 pm
Post new topic Reply to topic  [ 166 posts ]  Go to page Previous  1 ... 5, 6, 7, 8, 9
 Post subject: Re:
PostPosted: Sat Oct 13, 2012 10:51 am
[quote="theLUVman"]1978- first year for round gauges just to clarify that
1979- muffler was moved to where the spare tires usually went for 78 and 80. i think this was the only year it was here. spare tire went on a mount atached to the inside of the bed behind the driver.
I have a 79 Mikado, the spare tire is under the bed
PostPosted: Sat Oct 13, 2012 3:17 pm
I think I posted about the spare in the bed deal before. California 4X4 had the spare tire in the bed due to the muffler being mounted where the spare usually was due to the cat converter being mounted where the muffler usually was. Also the exhaust exits on the other side of the truck then the 2wd models. I am working on all the info in this thread and more info I find.
PostPosted: Tue Jan 29, 2013 6:37 pm
This thread could use some updating and corrections. I can see even a few things that aren't right in my original post. Been a long time, learned a few things since then. :)
PostPosted: Sun Sep 27, 2015 10:01 am
So, something I have not seen on here, and I just finished reading through all 9 pages of this thread. What year did they change the master cylinder to incorporate the proportioning valve separate from the master, and the ports come out the passenger side instead of the driver's side? If my research through NAPA i correct, this appears to be a 1979 change. I can tell you that my 79 has it, and my 74 and 75 have the older style with the fron lines being split right at the cylinder.
PostPosted: Tue Mar 21, 2017 11:54 pm
Did a page get created like Ben mentioned w/ a list of these changes from Year to year ?
PostPosted: Tue Sep 24, 2019 10:08 pm
I have an 1980 Cali Emissions 4x4 model. The spare tire is in the bed (pictured) and the engine bay is way more complicated and annoying, due to vacuum and emission lines. I also looked under the bed and saw that the muffler was where the spare tire would normally be. Just wanted to keep this old thread alive.
Users browsing this forum: No registered users and 65 guests
