It is currently Sun Jun 07, 2026 7:07 pm
PostPosted: Mon Jan 14, 2013 10:46 am
I just replaced the engine in my 1980 luv with an engine from a 1981 luv. the original coil is still in the 1980 luv (the coil that worked with the "points style" distributor), but I do have the coil from the 1981 (the coil being used with the electronic distributor). my question is; how do I hook up the electronic distributor from the 1981 to work with the setup in the 1980? there are two wires coming from the electronic distributor ( one red and one white), and can this electronic distributor work with the original coil from the "points style" distributor? if not, what all needs to be done to make this electronic distributor work?
PostPosted: Mon Jan 14, 2013 4:55 pm
one wire to + on coil one to - on coil. set timing, gap plugs to .040, drive away and never touch points again..
im using an 85 pup electronic distributor in mine have been for a year or so now i can rev it out a lot higher than the points and i havent noticed any missing like i did before
