It is currently Mon Jul 14, 2025 7:00 am
Post new topic Reply to topic  [ 31 posts ]  Go to page 1, 2  Next
 Post subject: my luv has no spark
PostPosted: Sat Dec 15, 2012 6:14 pm
so i just got a 1978 chevy luv that sat in a field for 5 years for $100. everything is working on it except the fuel pump and i dont have any spark. ive replaced the coil so far and still the same, next im going too try the wires. any other ideas what it could be?
I'm workin' on it
78 chassis with 75 cab
SBC
 Post subject: Re: my luv has no spark
PostPosted: Sun Dec 16, 2012 1:23 am
anyone??
I'm workin' on it
SBC
PostPosted: Sun Dec 16, 2012 3:24 am
have you checked the distributor? sitting that long the points are probably pretty dirty or corroded. mine used to give me issues often
PostPosted: Sun Dec 16, 2012 7:04 am
X2. Points fried or adjusted improperly.
PostPosted: Sun Dec 16, 2012 11:07 am
the distributer seams "ok" but i am not getting any spark at the end of the coil wire either. ive replaced the coil and so far nothing. gonna do the wires and if that doesnt work would it be the wiring too the coil?
I'm workin' on it
SBC
PostPosted: Sun Dec 16, 2012 7:53 pm
Don't jump all over guessing and replaceing parts. Clean the points with a point file and check the gap when open while stopped on the lobe highest spot-- .018 thousands gap. Or just replace them. Have someone help you if you don't know how to do this properly. Points have to work first to get spark anywhere.
PostPosted: Sun Dec 16, 2012 10:42 pm
well ill be changing the coil wire and today i cleaned the points, i got 1 spark at the end of the coil wire after turning it over multiple tries.
I'm workin' on it
SBC
PostPosted: Sun Dec 16, 2012 10:47 pm
Make sure you have power to the coil, in fact I would jump power from the battery to the coil, replace the points and I am sure it will have spark.
PostPosted: Sun Dec 16, 2012 10:58 pm
ill try and jump it, hopefully that will work . if not i'll do the points
I'm workin' on it
SBC
PostPosted: Sun Dec 16, 2012 11:28 pm
My reasoning is that the bypass relay could be bad.
PostPosted: Sun Dec 16, 2012 11:45 pm
ok well i jumped it from the battery to coil, and it just kept turning over with no spark. touched the coil and it was HOT so i knew i has some crossed wires. fixed that issue, put on a new coil wire and i now have spark and got it too run for a couple seconds. now i need too figure out my fuel pump issue. is there a relay for the fuel pump that might be dead? and are they inline or in the tank?
I'm workin' on it
SBC
PostPosted: Mon Dec 17, 2012 12:12 am
the relay should be inside the little square box on the passenger side inner fender.
wouldnt hurt to replace the 2 that are in there, the fuel pump is in-line, driver side, under the bed on top of the frame. i had to replace mine 4 times because my relay was shot, worth the few bucks to replace both relays and have that ruled out of any future problems you may run into
PostPosted: Mon Dec 17, 2012 12:22 am
cant seem to find the relays. only little box is on the driver fender with the 5 or so glass fuses. and thanks so much for the info on the fuel pump!
I'm workin' on it
SBC
PostPosted: Mon Dec 17, 2012 3:16 am
"little box" may be a bad description :lol: in the pic it is the box right above my air cleaner up against the fender well, rearward of the coil.. im pretty sure your 78 and my 80 are the same wiring-wise. you can see the small holes from the screws that hold the relays on from the inside
if you need any info feel free to pm me and i will help out where i can.
PostPosted: Mon Dec 17, 2012 1:50 pm
thanks for the info! is there a way too change the wiring to go onto a standard 5 pin relay?
I'm workin' on it
SBC
PostPosted: Mon Dec 17, 2012 10:14 pm
got her fired up today! still not sure about the relays, i used another fuel pump hooked to a gas can. the carb is leaking like crazy anyone know of a place for rebuild kits?
I'm workin' on it
SBC
PostPosted: Mon Dec 17, 2012 10:22 pm
you have the original carb still im guessing? im not sure who has the kits but i know they are out there a few people have had theirs rebuilt. its a hitachi dch340 or dcp340 check the numbers on it. the stock carbs are pretty crappy to begin with tho. depending on how much it is goign to cost you to get it rebuilt you may want to look into getting a weber. they will go on the stock intake with an adapter from redline weber. they sell a full conversion kit as well.
did you find the relay box? i left my stock relays where they were, (wasnt sure which was which) and wired in 2 new ones next to them one running the fuel pump (all new wiring) and one running my stereo and a few small things like that.
PostPosted: Tue Dec 18, 2012 12:13 am
sorry for the late reply been playin in the snow with the trucks!. yep found the relays but they are weird. one is a 4 pin all in a row and the other is like a 5 in a row. and i still have the original carb, and dont have the funds to get a weber. ive rebuilt a couple carbs so it shouldnt be a problem, just wondering if there are rebuild kits out there. thanks for all th info again!
I'm workin' on it
SBC
PostPosted: Tue Dec 18, 2012 1:05 am
i installed newer bosch style 5 pin relays so i wouldnt have to put a bunch of wire on the 1 output of a 4 pin. will eventually tear everything out and re wire all of my engine bay. lots of mickeymoused wiring there and under the hood.
and i feel ya im about to head up to larch mountain to get my luv stuck in the snow :lol:
PostPosted: Tue Dec 18, 2012 11:25 am
ok well thanks for all the info! im thinking i'll just rewire the fuel pump since i cant find those relays anywhere. and i wish my jeep could get stuck in the snow! ive never been able to get it stuck, especially now that its locked front and rear :D
I'm workin' on it
SBC
