It is currently Thu Jun 25, 2026 2:16 am
Post new topic Reply to topic  [ 189 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7, 8 ... 10  Next
PostPosted: Sat Dec 01, 2012 10:50 pm
Torsion bars are the next thing to go. Should be able to finish mocking up the motor after that.
My names Trevor BTW. ;)
PostPosted: Mon Dec 03, 2012 9:46 pm
PostPosted: Tue Dec 04, 2012 7:32 am
very nice, making good progress 8) have you figured out which coils you want to run?
PostPosted: Tue Dec 04, 2012 11:13 pm
these are the coils iv'e decided on http://www.speedwaymotors.com/QA1-Adjustable-12-Inch-Coil-Over-Shock-Kit,37211.html
PostPosted: Sat Dec 15, 2012 7:32 pm
Cutting the clearance very close
Just a couple of shots of the motor mounts
Cleaned up some of the old cuts I did and modified the under the engine crossmember bolt up area , still need to modify the crossmember itself.
you can see the pieces of the crossmember I cut off lying of the floor.
Engine shimmed on jack stands where it will sit once the motor mount brackets are fabbed up. Level left to right, and 1-2 neg- degrees front to back to compensate for when the coilovers are installed since the truck is sitting on the bump stops atm. Oil pan to bottom of tire clearance( I would say oil pan to ground clearance but the truck is sitting on blocks on all 4 tires.)
PostPosted: Sat Jan 19, 2013 12:24 am
Bought a welding tank today along with a welding helmet, so I should now be able to continue with the motor mount.
PostPosted: Wed Jan 23, 2013 11:01 pm
Picked up a few supply's, and am going to try and work on the truck this weekend. :)
PostPosted: Mon Feb 04, 2013 12:12 am
So turns out the welder I had bought did not have enough amperage (135amp) for the steel I bought for the motor mount brackets or for the frame its self. uprgraded (to 175amp) it, but now Iv'e got to have a 220v plug put in my garage.
PostPosted: Sat Mar 16, 2013 11:41 pm
A little progress.
PostPosted: Sun Mar 17, 2013 11:48 pm
Well.... they looked good before I stated welding on them. But there in. Oh, And btw I hate arc welding. (sigh)
Tacked in place
Final welding.
PostPosted: Wed Mar 20, 2013 11:41 pm
Can't think of anything to say about these atm.
PostPosted: Sun Mar 24, 2013 4:58 pm
Lookin Good!
Racing aint a hobby...its a passion
PostPosted: Sun Mar 24, 2013 7:34 pm
ImLuvinIt wrote:
Lookin Good!
Thanks.
PostPosted: Mon Mar 25, 2013 4:16 am
I am impressed with your determination!
I know nearly nothing about rotary engines, so when I see yours, my eyes revert to the deer in the headlights look... 8O
I can't figure out what is what, up or down, or in or out.
My engine brain is still stuck in the carburated 1970's and '80's. Boy, I need to catch up with the times. :oops:
PostPosted: Mon Mar 25, 2013 11:49 am
nicely done.
PostPosted: Mon Mar 25, 2013 9:59 pm
Just think.
The sound these engines make a full tilt is what made me want to do this. Have always wanted a rotary but was unwilling to give up the LUV, and so I decided to join the two.
PostPosted: Mon Mar 25, 2013 10:00 pm
Thank you guys for the positive feedback on this project.
PostPosted: Tue Mar 26, 2013 9:38 pm
Made a little progress tonight.
PostPosted: Sun Apr 07, 2013 5:11 pm
On the bump stops I have about 3 1/2in ground clearance 6in at ride height.
transmission crossmember bracket tacked in place.
PostPosted: Sat Apr 13, 2013 8:56 pm
