It is currently Wed Jul 01, 2026 9:08 pm
Post new topic Reply to topic  [ 42 posts ]  Go to page 1, 2, 3  Next
 Post subject: Turbo ?
PostPosted: Thu Dec 11, 2003 12:09 am
has anyone here actually put a turbo or twin turbo on a stock 1.8 luv pickup i heard you can take a turbo off the isuzu impulse too ?
jus another ? in my head
PostPosted: Thu Dec 11, 2003 7:29 am
i've sat for a long time thinking about that.
thats what i wanted to do so i could keep my 4 wheel drive.
i've heard it's possible but have never heard of anybody doing it. :?
as you can see in the picture below theres way much more to a turbo than you'd think ( atleast i did ). this is a 2 liter motor too. i've heard you could swap out the heads and it would work. you also gotta find a way to make the fuel injection work.
so my thought it would just be easier to swap out the whole motor.
i've looked everywhere and couldn't find nothin. let alone find a impulse that had turbo.. :(
it would be sweet though wouldn't it :o i bet a luv would be nice with turbo and a good exhaust :D
if you do find a way let my ass in on the secret. i atleast want a turbo until i could afford a 350.
PostPosted: Thu Dec 11, 2003 9:13 am
i have been researching on the net about it i found that you can make an electric turbo out of leaf blower or shop vac change with high volume oil pump and probably oil pan and i heard you should use stock cam dont know why they say it runs better
just seeing if anyone here has put a turbo in theirs yet
hey bcg if i accomplish this yes i will share with everyone :D
PostPosted: Thu Dec 11, 2003 3:20 pm
i've love to find a way of running a turbo/supercharger on my carbed pickup. a little bit more simplistic, but i can't seem to find anyone who makes any parts that would work on a toyota motor(outside of a 22RTE)
PostPosted: Fri Dec 12, 2003 1:07 am
whoa dude check out this months hot rod magazine they got a section dedicated to turbo in your vehicle i bought it then later saw a section of it and was like score shows twin turbo small block 350 for all you runnin one good gains with twin turbo :D like 600hp plus you actually have to change a lot of parts though but more effecient way of gettin power read it
PostPosted: Fri Dec 12, 2003 10:16 am
i had to throw this in. :D very nicely done :D
this is what i'm thinking of doing. it has fuel injection and a header.
i'd want to get this and drop in a 5 speed. i bet it'd cruise too :D
and there easy to find :D :D :D
PostPosted: Fri Dec 12, 2003 10:35 am
guess it helped if i told ya what it came from.
85 impulse
check this guys pictures out 8O 8)
http://www.cardomain.com/memberpage/246399/1
PostPosted: Fri Dec 12, 2003 6:15 pm
nice the engines you say are easy to come by ehh! hmmm
well ill check into it, bout the leaf blower idea i dont think i ll do that leaf it up to some one else :lol: and i might be gettin 2 turbos for free not a sure deal yet
PostPosted: Sat Dec 13, 2003 1:00 am
maybe I'll hook up my leaf blower and see if I can keep the leaves from accumulating in my vents :lol:
Resident lurker
PostPosted: Sat Dec 13, 2003 2:17 am
Resident Sparktrician
Yeah, no shit. Too bad the inverter to power it is ~$75....
Lots and lots of wet wet leaves right now. I hate winter...
Kuranosuke
Grampa's Driving:
1990 Luv 4X4 "Family Cab"
got BOOBIES? 8O 8)
PostPosted: Sat Dec 13, 2003 2:45 am
check car-part.com
i looked and saw they had some junkyards with impulse turbo motors in them
PostPosted: Tue Dec 16, 2003 12:07 pm
OG Lifer
I am designing a turbo set-up using a mitsubishi turbo. All I need to find is a side draft carb with abut the same cfm as a 32/36 weber. Any suggestions?
WATCH YOUR PIEHOLE!!!!!!
PostPosted: Tue Dec 16, 2003 4:57 pm
i think a 40 DCOE is the smallest side draft they make. not that much bigger than a 32/36 but might kick a little more ass with 2 of them
PostPosted: Wed Dec 17, 2003 2:45 am
OG Lifer
I am getting the engine rebuilt with a bigger cam and more compression before I finish the turbo setup, so more cfm might not be a bad thing. Thanks :wink:
PostPosted: Wed Dec 17, 2003 2:46 am
what's up grimace :lol:
PostPosted: Wed Dec 17, 2003 9:34 am
alright grimace send us some pics of before and after and what kind of compression ratio you gonna have ?
PostPosted: Wed Dec 17, 2003 11:13 am
OG Lifer
Probably gonna run 8.5 or 9 to 1. I don't want to have it too radical, it is still a daily driver. It is gonna be lifted with a set of 33 inch boggers. I wanted more power in the mud, and this might be the answer.
WAAAAAAASSSSSSUUUUPPPPPPP BCG!!!!!!
PostPosted: Thu Dec 18, 2003 12:31 am
dude that would be good for mud except more parts to break in the mud :) 8) i was told to run stock compression
PostPosted: Thu Dec 18, 2003 4:39 pm
OG Lifer
I had a 70 blazer with 18 inches of lift, a 400 horse 327, military axles, and 44 inch tires. 5.87 gears, and lockers at both ends too. I have built a couple of mudders before. Is stock compression more than 9 or less than 8.5? I am thinking of a turbo 2.0 out of an impulse.
PostPosted: Thu Dec 18, 2003 5:26 pm
good luck man,
