It is currently Tue May 12, 2026 10:23 am
 Post subject: Water Temperature
PostPosted: Mon Sep 17, 2012 8:19 am
How Hot is too Hot. My truck runs around 190° to 195° 99% of the time. Last week with the weather above 100° it was running closer to 200° in traffic. Once I started moving it would drop back to the 190° to 195° range. Is this something I need to worry about. I just replaced the radiator last month.
76 LUV
 Post subject: Re: Water Temperature
PostPosted: Mon Sep 17, 2012 10:21 am
Seems OK to me. As long as it doesn't get any hotter, and it did cool it self back down once you were moving.
PostPosted: Mon Sep 17, 2012 10:58 am
I agree. It will run at the temperature the thermostat is set at. 195 is a common temperature setting of most thermostats today. The Luvs operated on a 180 deg thermostat OEM.
PostPosted: Mon Sep 17, 2012 5:58 pm
not sure of temp i still run stock gauges but i know mine is almost always right on the mark for stock temp. sometime slightly over when doing 70 but usually right on ... i also have no grill right now so i get plenty of cool air :lol:
PostPosted: Tue Sep 18, 2012 7:29 am
Thanks for the quick response. On the ride to work this morning it ran right around 185°.
76 LUV
Users browsing this forum: No registered users and 100 guests
