It is currently Mon Mar 16, 2026 10:38 pm
Post new topic Reply to topic  [ 58 posts ]  Go to page Previous  1, 2, 3  Next
PostPosted: Fri Mar 09, 2012 11:53 pm
Whole_lotta_luv wrote:
Radiator is mounted. I'm going to shove a artec quart crate between it and the fuel cell, then a couple of batteries are going to be mounted right behind the cab.
Nice!
PostPosted: Sun Mar 11, 2012 9:02 pm
Thanks
Balls deep in a transmission mess right now. Had a 2wd th350 laying around that I'm using for the case, bought 4wd th350 with a busted bellhousing for the output shaft/adapter, and bought a t-case at a swap meet.
Also ordered a 5 gear planetary set and a ring gear for a 700r4 to stuff in it, which will give me a lower first gear ratio. It'll be buttoned up with a hughes rebuild kit, tci valve body and a deep pan that I've had laying around for years
PostPosted: Mon Mar 12, 2012 12:59 am
Thanks
very nice! will make it a little easier to lug those tires uphill :lol:
how much did you put into rebuilding the tranny?
PostPosted: Mon Mar 12, 2012 10:47 am
Couldn't really tell you. I bought the hughes rebuild kit, the valve body, the deep pan, and a shifter for it a few years ago, back when it was going to be a drag truck. The planetary set and ring gear cost me $150. This will be my first wheeling rig with an auto, hopefully it's worth the hassle :egeek
PostPosted: Fri Apr 13, 2012 11:42 pm
Kinda starting to look like luv again
Finally has a transfer case sitting in it
PostPosted: Fri Apr 27, 2012 8:41 pm
Shocks and a bedside are mounted
Simple mounts for them, and some rust holes to fix
PostPosted: Sun Apr 29, 2012 10:52 pm
Other bedside and the tailgate are gutted and mounted
PostPosted: Mon Apr 30, 2012 5:04 pm
8O that thing looks great! good to see it keeping the LUV look after all the custom work
PostPosted: Fri May 04, 2012 11:36 pm
this thing is going to be a monster
No luv right now =(
PostPosted: Sun May 06, 2012 10:01 pm
Thanks guys
Today I got the transmission together
Started with this
And a box/bench covered in guts
Somehow ended up with this
PostPosted: Mon May 07, 2012 11:42 pm
Shift rail modded, shifters bolted on, rear case support cut out, and it's all stuffed back in the truck
PostPosted: Mon May 14, 2012 11:04 pm
Worked on the crossmembers some.
Started filling in the floor/firewall
PostPosted: Sun May 20, 2012 12:42 am
Haven't had much time to work on it this week. Did manage to get the drivers side door bars and seat mount in.
Yes the door bars aren't much fun to climb over. No I'm not real excited to be running the kirkeys, nothing else will fit.
PostPosted: Sun May 20, 2012 9:39 pm
Man, that is a lot of door bars...
PostPosted: Wed Jun 20, 2012 2:17 pm
Floor/tunnel is pretty much finished, minus a lot of welding/grinding. Been busy playing with dirtbikes, haven't touched this in a couple weeks. Tunnel is removable
PostPosted: Wed Jun 20, 2012 2:19 pm
Better than too few :lol:
PostPosted: Wed Jun 20, 2012 10:18 pm
Butchered some door bars for the passenger side. Then rolled it outside to sweep and let the truck enjoy western washingtons one day of summer
PostPosted: Sun Jul 01, 2012 11:26 pm
Ladyfriend snuck up like a ninja and caught me more or less working
Front is starting to take shape
PostPosted: Mon Jul 02, 2012 8:39 pm
Got the other fender roughed in. Got all giddy and had to tape everything together to see how it looked :grinpimp:
PostPosted: Thu Jul 05, 2012 7:43 am
man that thing looks great.. hell of a lot of work going into that thing 8)
cant wait to see the pair of them done and see how different they end up
