It is currently Mon Jun 29, 2026 9:44 pm
PostPosted: Sat Apr 14, 2012 6:13 pm
Was cleaning my egr valve out with a little drill. Wanted to get it good. So went a bit bigger. And bored the port too much. Am I doomed? Did I screw the pooch ?
PostPosted: Sat Apr 21, 2012 4:59 pm
Post a picture.
PostPosted: Sun Apr 22, 2012 12:48 am
Here it is.
PostPosted: Sun Apr 22, 2012 9:20 am
Make a new restricted orifice out of some rod material and insert it into the hose.
-DK
PostPosted: Sun Apr 22, 2012 10:05 am
If that is where the vacuum line attaches to the unit no problem. If it is an exhaust flow port then the size is important.
PostPosted: Mon Apr 23, 2012 8:10 pm
Its where the vaccum hose is. Any good rod material I should use ? Or type of adaption ?
PostPosted: Tue Apr 24, 2012 7:59 am
Sleeve some copper pipe into it.
PostPosted: Tue Apr 24, 2012 12:06 pm
If you know what the original size was just fill it with epoxy amd drill a new hole. As I said before if it is a vacuum line connection only, you don't have a problem anyway. Vacuum is sent there to open the valve under certain conditions. The exhaust flow amount is determined by a port inside the valve itself.
Users browsing this forum: Baidu [Spider] and 78 guests
