It is currently Tue May 26, 2026 9:30 pm
 Post subject: suspension swap ? 's
PostPosted: Sat Mar 10, 2012 8:34 pm
I have access to a 1986 toyota running gear with ifs this being front and rear axles, suspension tranfercase and prolly tranny if I need it along with erything like driveshafts and such. That being said I have a ' 80 4x4 would the toyota running gear be a compatible swap and would it give some lift?
 Post subject: Re: suspension swap ? 's
PostPosted: Sat Mar 10, 2012 11:19 pm
search.php
PostPosted: Sun Mar 11, 2012 11:31 am
Yea "mytmouz" said it, use the search button. There have been both, toy, jeep and dana44s axles used here. Good luck!
PostPosted: Sun Mar 11, 2012 11:52 am
I searched but couldn't find anything about whether the ifs would lift or fit
PostPosted: Sun Mar 11, 2012 12:31 pm
Anything will fit if you have the mechincal skills.
This truck has all toyota running gear in it.
ps, no I know nothing about it anymore, I tried to buy it about 12 years ago but the guy wanted about double what I wanted to pay.
PostPosted: Sun Mar 11, 2012 12:41 pm
The Toyota IFS is 4" wider F&R than a LUV. It would be a lot of work & fabrication to mount it to a LUV frame. Much easier would be a solid Toy front axle & you can get all the lift you want fairly easily.
