It is currently Mon Feb 02, 2026 2:21 pm
Post new topic Reply to topic  [ 24 posts ]  Go to page Previous  1, 2
 Post subject: Re: Driveline questions
PostPosted: Fri Mar 09, 2012 1:15 pm
yes there was a 5sp gas in 83/85 with the 1.9L and 4sp with the 1.9L
granted a gassier with a 5sp and 1.9L stock is rather rare.
as to 81/82 hmm good queston, if thers a gas with a 5sp.
in 86 when the 2.3L came out and the 1.9L became a 2wd 4speed only model.
its the last isuzu to get the 17 spline trans, in 86/87 and its a 4sp.
in no case is a trans bolted to a 1.8L or 1.9L an up-grade 26 spline trans
86trooperT/D 2.2
84 L\B 4x4Diesel LS 2.2
86 L\B 4X4 gas 5 speed 2.3
PostPosted: Fri Mar 09, 2012 2:39 pm
OK, now I know.
So now the OP must count tailshaft splines.
PostPosted: Fri Mar 09, 2012 2:57 pm
oldestisuzuist wrote:
OK, now I know.
;) Now you see why I said:
JoeIsuzu wrote:
So, one more question. And if you can't answer this one, you might as well give up. Because nobody can help you unless you tell us this: How many splines are on the output shaft of this 5-speed transmission?
PostPosted: Fri Mar 09, 2012 4:07 pm
epic thread
