It is currently Mon Jun 22, 2026 10:44 am
 Post subject: 77LUV
PostPosted: Wed Feb 29, 2012 7:35 pm
Well, I'm back. Pouring through the archives I found that the 77 was the last year for the hydraulic clutch. Therefore, the 78 must have a cable clutch. Y'all think that is right?? Thanks...Don
 Post subject: Re: 77LUV
PostPosted: Wed Feb 29, 2012 9:48 pm
My 77 has one of those POS.
PostPosted: Thu Mar 01, 2012 9:45 am
lol. I think you are correct on the switch from hydraulic to cable.
I like the hydraulic clutch... makes swaping a different transmission in easier and Wilwood makes a master cylinder set up that bolts in the stock place of your old one.
Eric Q.
My build thread.
PostPosted: Thu Mar 01, 2012 10:38 am
Labman...Is your LUV a 77 too--with the cable clutch? I bought a 77 transmission a couple of years ago that arrived with the throw-out lever on the left side. I have the hydraulic lever on the right. I figured the wrecking yard sender got everything wrong and I had planned to return it this summer while on vacation. My only defense would have been that THEY messed up and sent me the wrong one as I thought the lever position change was made in '78. Thanks.....Don
PostPosted: Thu Mar 01, 2012 11:38 am
No I have the stupid hydrolic clutch I have had to rebuild the cylinders who know how many times. I have studied converting.
PostPosted: Thu Mar 01, 2012 9:51 pm
The slave or the master Labman?
Users browsing this forum: Baidu [Spider] and 43 guests
