It is currently Sat May 23, 2026 5:24 am
Post new topic Reply to topic  [ 454 posts ]  Go to page Previous  1, 2, 3, 4, 5, 6, 7 ... 23  Next
PostPosted: Tue Jan 03, 2012 7:58 pm
Nice looking truck and the build is comming along nice!
Reminds me when I dropped a 327 in mine!
I used the Hooker headers also.
What radiator are you using?
I've always had a bit of cooling issues.
Thanks for posting the pictures!
PostPosted: Wed Jan 04, 2012 5:54 am
I have an after market Welded aluminum . Thinking it is 22 x 19 that was with the truck when i bought it . I would trim the core support out and see if a 24 x 18 or 19 would fit . Drove it around a bit this weekend . Street car
PostPosted: Sun Jan 29, 2012 9:44 pm
New rear wheels
Chassis dyno sceduled Friday @ 10 . Then Chromemolly the following monday. Here is the currents . Added some LED boat lights . Truck had a direct short im the running lights . Everytime i pulled the lights on it blew the fuse . The horn didnt work either . Dash lights had none factory lights scabbed in , so i cut all that out and fixed the factory dash lights . All connections soldered and heat shinked . Put the dash back together and installed new horn and Mikado wheel Everythong is legal except emergency brake , but it think i can still get a sticker Probably end up with a disc on the rear end yoke . I also pulled the old tack and added one of the new auto meter auto sticks . Ready to put tunes in . A/C & heat next . Plate ,, noids and hoses going to Induction solutions coming up . Then power steering .
PostPosted: Sun Jan 29, 2012 9:46 pm
Me like...
PostPosted: Sun Jan 29, 2012 9:50 pm
Also ordered 1 gallon fuel cell to run race fuel in for the Nitrous . It will be front mounted .
PostPosted: Mon Jan 30, 2012 6:46 pm
I just did that to mine...it turned out well PM me your email and i will send you some pics for some ideas
Its NICE when you run pump gas on motor :)
PostPosted: Wed Feb 01, 2012 6:28 pm
here are a few
I run a 26 jet on the return line and could be alittle smaller the pressure drops about a 1/16lb with the soleniod opens but other than that works perfect....
After doing it I should have went with the Nitro Daves universal tank. Or if you can figure out how to mount the walbro pump inside the tank it would be WAY cleaner...
PostPosted: Wed Feb 01, 2012 9:33 pm
Thanks , i already have the blue pump and reg . I will probably solder up a Holley jey and do a .018 return orfice . Mine will be very similar .
PostPosted: Thu Feb 02, 2012 6:58 pm
Only problem I dont like is while testing it after it gets to about a 1/4 tank the pump can starve. Guess its the -8 lines but with no guage and the tank is foam filled its not a quick look. Probably pull mine back out and make a bolt in sight glass for fuel level.
PostPosted: Tue Feb 07, 2012 8:56 pm
Well im getting closer and i will top off the tank after every pass . I dri;;ed and tapped a 90 and threaded it foe a Holley carb jet . I then soldered up the jet and drilled a .048 hole in it for the bypass .
PostPosted: Sun Feb 19, 2012 9:55 pm
went 4 rounds today footbraking on motor and drag radials
PostPosted: Sun Feb 19, 2012 10:06 pm
Very nice!
PostPosted: Mon Mar 05, 2012 9:00 pm
Pic update . Caltracs on , new hood painted , rear fenders painted 1 installed . Swapped to 4.11 . TH400 with transbrake is in .
Golf cart getting painted and ready for this season of racing .
PostPosted: Mon Mar 05, 2012 9:19 pm
Here is the new hood installed .
PostPosted: Tue Mar 06, 2012 12:42 am
Sweet!
PostPosted: Tue Mar 06, 2012 3:57 pm
Just got the pics of the finished golf cart . Let me know what you think .
PostPosted: Tue Mar 06, 2012 4:34 pm
Awesome! 8)
PostPosted: Tue Mar 06, 2012 7:49 pm
LSX LUV Owner
Very nice! Looks better on a computer and not a text lol!
PostPosted: Tue Mar 06, 2012 9:46 pm
Look you need this hood and i cut you a smoking deal on the bumper . come and get it .
PostPosted: Wed Mar 07, 2012 7:40 am
LSX LUV Owner
Let me know a price. I'm interested!
