It is currently Wed Jun 10, 2026 2:52 am
PostPosted: Tue Jan 10, 2012 2:06 pm
Hi there.
When I bought my '80 LUV, the needle would always hang out at the 3/4 of the way hot mark, but never got any higher than that. I had an oil leak fixed and after that it started showing all the way hot, all the time. I took it to a mechanic and they changed out the fan assembly and when I picked it up they told me that it's reading hotter than it actually is.
It's still showing all the way hot. It is not steaming. I bought an infrared thermometer. I'm not sure where I am supposed to point it or what is a safe temperature? If it's not really overheating I'll try to buy a new gauge, but if it is I need to fix the overheating issue. I would rather not take it back to the shop.
Thank you!
PostPosted: Tue Jan 10, 2012 5:26 pm
The manual tells you how to take an Ohm reading with a multimeter on the temp sensor cold and hot. I can't remember what the range is off the top of my head. This will at least tell you if your sensor is good or bad. I don't think I've ever heard of a temp gauge going bad on a Luv.
PostPosted: Tue Jan 10, 2012 8:56 pm
You would want to point the infrared gauge at the thermostat housing and or the radiator. I would guess when the truck is fully warmed up it would read up around 170.
PostPosted: Tue Jan 10, 2012 11:12 pm
Take a reading off the lower radiator hose after it is warmed up. The rubber hose will read closer to the actual water temp than any metal part you take a reading of...
PostPosted: Wed Jan 11, 2012 12:39 am
A quick check of the gauge: Key on, disconnect the wire from the sending unit, gauge should read cold. Ground the disconnected wire, gauge should read max hot. This means the dash gauge is ok.
PostPosted: Wed Jan 11, 2012 7:57 pm
Top radiator hose, various locations on the engine block, thermostat location, reading in the 180-230 range.
Spark plugs 280 (i don't know, we were pointing it everywhere), lower radiator hose 145.
Does this sound right/okay?
PostPosted: Thu Jan 12, 2012 1:37 am
Sounds ok. Try the "quick check of the gauge" tip...
