It is currently Wed Jun 24, 2026 7:28 am
 Post subject: Guage lights dont work
PostPosted: Tue Nov 15, 2011 12:09 pm
Have a stock LUV and my guage lights dont work. The engine light comes on when you start-up and the brake warning light works, but none of the display lights work. When driving at night, its really hard to see. I bought the truck with the lights not working so its not something that just stopped on me one day. I checked all the bulbs and they are good. Any help would be appreciated. The wiring diagram in the manual is impossible for me to trace, so....
PostPosted: Tue Nov 15, 2011 12:57 pm
Check your fuse's, fuse box and connections. I went thru two headlight switches thining that was the problem but it was actually a blown fuse...
PostPosted: Wed Nov 16, 2011 12:28 pm
I checked all my fuses to include the ones under the hood. I didnt find any blown. Thanks for the reply!
PostPosted: Wed Nov 16, 2011 12:35 pm
My wipers and radio randomly cut out when I first bought the truck. To remedy it I took apart the fuse block and scrubbed it with a toothbrush and some lemon juice until the connectors were spic and span. Problem solved.
As for the wiring diagram, I find it's easiest to follow if I trace the line with the point of a pair of scissors, seems to keep things a little clearer and you don't get lost in the riffraff.
good luck.
1978 Mikado *Weber 32/36*Offenhauser intake manifold*Pacesetter header*Custom exhaust*Pertronix Ignitor & Flamethrower 40,000v coil*
PostPosted: Wed Nov 16, 2011 1:02 pm
The headlight switch controls the interior lights so you might have a bad switch. There are also two hot wires going to the headlight switch, one for the headlights, the other for interior and running lights. If you didn't know. I checked all my lights at the headlight switch connector, with a lil length of wire I jumped from both hots(one at a time) to each of the other three terminals in the connector. Headlights, running lights and interior. If the lights come on you have a bad switch, if they don't you have a wiring issue.
PostPosted: Wed Nov 16, 2011 8:15 pm
Did you try pulling the switch on and turning the knob? Variable bright/dim?
