It is currently Wed Jul 01, 2026 4:58 am
 Post subject: rpms and oil pressure
PostPosted: Wed Nov 19, 2003 6:49 pm
i was wonderin bout how high of rpm's the luv can take
and what psi of oil pressure it should run also
sorry i am a newbie thanks in advance
oh also i need to find where some one sells the offenhauser intake and
Mepr told me bout the hard to find rv cam which i dont know to find also
PostPosted: Wed Nov 19, 2003 8:24 pm
well as for the rpm's.ive held my to the floor in 1st gear low loc tell it sounds like its going to blow in a million pieces.and that was after i topped the hill or come out of the mud hole lol.i dont think they will blow up.
PostPosted: Wed Nov 19, 2003 9:19 pm
man its like at 2grand its screamin like its goin to blow up in first and second gear but third and forth is not that bad but i figure 3000 is normal shiftin right :?:
PostPosted: Thu Nov 20, 2003 1:19 pm
psshh... ive gotten my old luv upt to almost 5 grand before, i doubt those engines can blow up.
Currently no more luv's... But in search of one!
PostPosted: Fri Nov 21, 2003 1:34 am
right on well how bout oil pressure now that i feel safe bout rpms cause i found an oil psi gauge in are garage i was like sweet freebie
PostPosted: Fri Nov 21, 2003 1:15 pm
Your oil pressure should range between 40 and 60 lbs. thats where mine stays at.
PostPosted: Sat Nov 22, 2003 11:48 am
alright thanks man for the help
