It is currently Sun Aug 02, 2026 3:03 am
Post new topic Reply to topic  [ 454 posts ]  Go to page Previous  1, 2, 3, 4, 5 ... 23  Next
PostPosted: Tue Jul 26, 2011 9:12 pm
Ben wrote:
hotrod80 wrote:
They are the Hooker conversion headers . I intend to have the slip fit on the passenger side modified with a flange . I always had an exhaust leak their .
I did this on a set and it worked great.
Good to know someone else has done this . My Blue truck always seemed to have a pop on that side . In some of the videos you could see that side flicker when spraying it . Also looking into having them coated on the inside and out to preserve them and help with heat .
Spent a little time today measuring under the dash . entertaining putting a street rod a/c system in it .
Also i think the fleet side bed allows for more tire options than the stepside . 275/60/15 drag radials fit but look like they are gonna rub . I had plenty of room with the blue truck and the same tire
PostPosted: Wed Jul 27, 2011 1:06 am
The Jethot is amazing...just had a set done for the the modified. They are pricey but they honestly look like chrome. I will post a pic. The A/C would be worth its weight in gold we just hit 35+ days over 100* I was raised that real hotrods dont have a/c...I am begining to disagree.....Where does the tire rub on a stepside? Thought they would be the same unless the width of the opening is different.
PostPosted: Wed Jul 27, 2011 3:39 am
I got jet hot on mine, it will eventually peel. Lifetime warranty is not in effect if they coat used stuff, or if you lose your reciept. Oh, and dibs on the stepside bed, lol...
PostPosted: Thu Jul 28, 2011 8:39 am
Well the stepside box is about 1" wider than the frame rails , so it takes up some of the backspace room and the step fenders are a little narrower then the fleet bedsides . I also found the box to be off by a little side to side so i will be moving it some .
Oh. and it will stay a stepside . Sorry TP :D .
PostPosted: Thu Jul 28, 2011 10:59 am
:cry:
PostPosted: Thu Jul 28, 2011 10:32 pm
Here is a pic of the coating in question..they are coated inside and out. This is only pressured washed after last weekend. And these have 44 laps at 8200-8400 RPM. I can let you know how they hold up but the best I have seen.
PostPosted: Wed Aug 10, 2011 6:16 pm
Getting a little farther along , kinda slow going due to work , heat , daughter going to college . Made some progress though .
PostPosted: Fri Aug 12, 2011 8:22 pm
looking good sir!!!!! how them M/T'S fitting?
i guess i need to change my avaitar.
PostPosted: Wed Sep 21, 2011 8:16 pm
They are tight , but fit .I am working on it more now that it has started cooling off some .
PostPosted: Wed Sep 21, 2011 8:25 pm
Headers are on . Trans mount is in , shifter hookrd up , waiting on pulleys and alt bracket . Here's a pic update .
PostPosted: Wed Sep 21, 2011 8:41 pm
8) I was wondering...
PostPosted: Thu Sep 22, 2011 7:08 am
It is getting there . The heat , college bills and trying to keep stuff -17 in this heat at work have had me busy
PostPosted: Tue Sep 27, 2011 9:02 pm
Ok Trans lines are run , dipsticks in , moved the radiator forward more and clearenced the cross member . Really considering putting an aftermarket shifter in and Losing the factory heater assembly for a street rod style A/c heat combo . Bought a 3.60 gear and it is looking like a used nascar detroit locker will be next . Also considering a Chevelle/nova style gas tankwith sump and roll pan with flip down plate for filler. It is really close . Still waiting on alt bracket .
PostPosted: Tue Sep 27, 2011 9:44 pm
Jedi Pimp Master
Hey! Are those my stepside fenders hanging on your shop wall?
SRAD
My Wife is faster than you think you are
PostPosted: Wed Sep 28, 2011 5:56 am
SRAD
i bought those when i had the truck from a guy here in spring,unless ur that guy?
PostPosted: Wed Sep 28, 2011 7:37 am
They are . These will add almost 1" to rear tire clearence .
PostPosted: Thu Oct 06, 2011 5:30 pm
Found this last night on Craigslist and stole it out from under CT for $350 in Conroe and a picture of the Caltracs out of the classifieds .
PostPosted: Thu Oct 06, 2011 8:23 pm
we are not friends anymore hotrod!!!!!!
i can't wait to see and hear the truck again, ought to be a runner that's for sure.
PostPosted: Thu Oct 06, 2011 8:31 pm
You had a 400 in it before ?
PostPosted: Mon Oct 10, 2011 5:08 pm
sbc 400 but a th350 trans.
Users browsing this forum: No registered users and 54 guests
