It is currently Sun Apr 12, 2026 8:53 am
 Post subject: trans seal
PostPosted: Thu Jul 14, 2011 11:43 pm
i am having trouble finding a rear input trans seal for my 1779 chevy luv 4 speed manual trans. I went to a chevy dealer and they told me it was discontinued. the only numbers on the seal are 8-94223-026-0 if any one has info on were to find seals for these 4 speed manuals that would save my truck
 Post subject: Re: trans seal
PostPosted: Fri Jul 15, 2011 8:34 am
I'm confused, what rear input trans seal? The input is on the front the output (tailshaft) is at the rear. Output shaft seal is Timken #1987, same number for several different brands, fits 2wd for sure, should fit 4wd.
If you have a 4wd & are asking about the front driveshaft seal it is for the transfer case, not the tranny.
PostPosted: Fri Jul 15, 2011 9:03 am
I sent him a PM with Jerry's email address.
PostPosted: Fri Jul 15, 2011 2:04 pm
thats what i thought to i was listoning to a parts guy and he told me the tailshaft was the input. thanks for the info. just one more question for ya were can i order that seal ? i went on the timken web page and could not find it
PostPosted: Fri Jul 15, 2011 6:30 pm
I agree. The "parts guy" you were "listoning to" is obviously not a mechanic.
That's not "one more question", it was basically what you asked in the first post--and I sent you the info via PM. Just tell Jerry what you're looking for, and he can probably get it.
PostPosted: Fri Jul 15, 2011 9:37 pm
Any good auto parts store should have them in stock. I did a quick check of the Autozone web page, they are listed. The last time I bought one they were a common in-stock part, & several different brands use the same #1987 part number, if they don't have Timken cross reference the number, get a different brand.
The problem with ordering one on-line or from Jerry is the shipping will be more than the seal.
PostPosted: Sat Jul 16, 2011 1:13 am
thanks so much for the info
PostPosted: Sat Jul 16, 2011 10:07 am
He sends small parts via USPS flat rate envelope. It's usually a couple or three dollars for mailing. I guess that's true if it's a $3 part, but how much will you spend driving around town?
PostPosted: Sat Jul 30, 2011 4:54 pm
i have a 78 luv with a 4 speed im trin to find out how too put a 5 in and where i may be able to find on
PostPosted: Sat Jul 30, 2011 8:03 pm
James, you probably oughta post that question in its own topic, since this topic is about getting transmission seals. There's a "New topic" button for that. Better yet, just go to:
Isuzu P'up 5-speed Swao...
PostPosted: Sat Aug 06, 2011 9:20 pm
thanks jack
Users browsing this forum: No registered users and 114 guests
