It is currently Tue Mar 03, 2026 12:14 pm
PostPosted: Mon Jun 13, 2011 11:01 am
So I just got a 1975 luv for free will be going to pick it up today, was running fine till slave cylinder went bad and leaked everywhere, where can I find one? Kragen nor napa auto parts had one. Engine runs fine and truck has been on ranch for last 20 years so low milage I expect, can anyone send me links and or good places to loom at parts? Thanks guys
PostPosted: Tue Jun 14, 2011 3:33 pm
http://www.oreillyauto.com/site/c/searc ... vi=1054303 this is a link for oreillys auto parts they had it in stock here
I will no longer do that thing with my tongue
PostPosted: Tue Jun 14, 2011 4:37 pm
Will the 76 fit the 75?
PostPosted: Tue Jun 14, 2011 7:29 pm
No, 73,74 and 75 are different then the 76 & 77 as per my parts book.
PostPosted: Tue Jun 14, 2011 7:37 pm
AAP has been able to order at least a kit for my 77. Try www.rockauto.com I have found the hydraulic clutch to be troublesome. I have even studied converting to mechanical.
PostPosted: Tue Jun 14, 2011 8:23 pm
NCF 73483
This is the part number NAPA has for it
PostPosted: Wed Jun 15, 2011 12:06 pm
Thanks guys!!! Got truck on road again
PostPosted: Wed Jun 15, 2011 12:09 pm
Now need some more stuff including tail lights and the chrome trim that goes around them and few other things, it's hard finding stuff for tis truck
PostPosted: Wed Jun 15, 2011 1:03 pm
Go to Ebay motors http://motors.shop.ebay.com/Parts-Acces ... p=10&_sc=1
PostPosted: Mon Jun 20, 2011 6:30 pm
on the 75 under water temp and fuel theres a C and O that tend to turn on from time to time what do they stand for? i just bought a mechanical water temp gauge since original dont really work, how hot should this thing run?
PostPosted: Mon Jun 20, 2011 8:39 pm
Well, with a 180 degree thermostat in it, it should not get too far above 180. If the cooling system is in top notch shape, it should only get to 180.
PostPosted: Mon Jun 20, 2011 11:54 pm
So the lights stand for?
PostPosted: Tue Jun 21, 2011 6:59 am
The C is charge. Be attentive to it. Unless the alternator is working, the fuel pump quits. The O is oil pressure.
PostPosted: Tue Jun 21, 2011 11:48 pm
The O is always on.... Start where? Any advise? Thanks everyone so far for feed back.
PostPosted: Wed Jun 22, 2011 7:36 am
There is a oil pressure sending unit on the right lower side of the block. Check it and the wire that is hooked to it,
PostPosted: Wed Jun 22, 2011 9:05 am
Do you have a repair manual? If not, get one asap.
PostPosted: Wed Jun 22, 2011 1:42 pm
thanks will look into that.
i do have manual but as of right now i left it at my friends house since hes gonna re wire all my lights and clean up the engine bay seems like last owner did alot of splicing to wires.
i work on audi/vw all day but newer ones lol i hate wiring stuff and my buddy is into that stuff so hes gonna help me out.
