It is currently Fri Jul 03, 2026 6:26 am
 Post subject: 5-lug help for newbie!
PostPosted: Thu May 26, 2011 11:33 am
Im sure this has been covered in previous discussions but I never really found the exact way to do this. I have a 1985 Luv and need to run a 5x4.75 front hub. I know some of the Toyota swaps make it a 5x4.50. Is there a direct bolt on to get the 5x4.75 other than the Aerospacecomponents.com way? Its just alittle too pricey for me. Any S-10, later model Toyota's, etc? Any help is appreciated thanks!!!
PostPosted: Thu May 26, 2011 1:35 pm
Not sure on the conversion but there are quite a few members that have converted, my main question is
are you sure you have an 85??? :econfused
PostPosted: Thu May 26, 2011 2:18 pm
Ooops sorry '82 thanks typing and talking don't mix.
PostPosted: Thu May 26, 2011 6:38 pm
Not sure about 81-82s but i used Toyota rotor/hubs on my 78 but they were 4.5 so your options are few.
PostPosted: Thu May 26, 2011 7:41 pm
You can have the toyota rotors redrilled for the larger pattern...
PostPosted: Fri May 27, 2011 6:39 am
Do the Toyota hubs and rotors fit without swapping the control arms?
PostPosted: Sat May 28, 2011 11:21 am
Yes but you need to machine spacers for the bearings to fit.
Check back on some of my posts and pic's and you can find the dimensions needed.
PostPosted: Sun Jun 19, 2011 11:50 am
Japanese Redneck
My friend designed his own 5 lug disk brake conversions for a while with the intention of offering a kit for sale but there wasn't enough positive response for him to justify having a shop set up tooling to mass produce the kits. If you are still interested, I can ask him if he will make a few setups. They run about $500 + shipping and include modified S10 rotors, pads, custom caliper mounts, calipers, bearings, basically everything you need to convert to 5 lug Chevy pattern (4 3/4") front disk brakes.
1978 LUV Truck 2WD
450 "Small Block" Chevy
3.70 Ford 9
28x10 Goodyears
