It is currently Fri Jul 03, 2026 12:13 am
Post new topic Reply to topic  [ 28 posts ]  Go to page 1, 2  Next
PostPosted: Sat May 14, 2011 10:30 pm
I have an 82 4x4 diesel luv with a 4 speed. It tops out at about 50 mph.
Is there a 5 speed tranny that I can swap it out with?
PostPosted: Sun May 15, 2011 8:45 am
I'm not positive but the 87 up Trooper and PUP's will fit with a bell housing change. There are others that know more about this and can help.
PostPosted: Sun May 15, 2011 4:16 pm
Thanks, Ya the starter is on the drivers side on the diesel. Thats where I run into the problem.
PostPosted: Sun May 15, 2011 6:33 pm
That's the reason for the bell swap. I put a 5spd. in my 80 4X4 and it was more than worth the trouble as cruising rpm is allot nicer.
PostPosted: Sun May 15, 2011 7:23 pm
Will the pup 5 speed work, or trooper? any modifications I need to knoww about?
PostPosted: Sun May 15, 2011 9:59 pm
Is the 5-speed from another diesel? If it's a diesel 5-speed, it will have the correct bell housing. But the 5-speed transmission is longer than the 4-speed, I believe. The mounts are in the wrong place, and I guess that means the driveshaft will be the wrong length. Is this a long bed, or short bed?
And something is wrong with your truck, it ought to top out around 65-70.
PostPosted: Mon May 16, 2011 1:50 am
I meant the rpms are way too high at 60-65. In 82 the speed limit was 55,The number on the speedometer is highlighted on the number 55. I have owned 4 luvs all were 82s. This is the first 4x4. It actualy is the best runner I have had yet. The others were 5 speeds.
I am looking at a 2002 trooper 4x4 tranny, will that work and if so any mods I need to make?
Bruce
PostPosted: Mon May 16, 2011 7:02 am
Oh, well now it makes sense. Right, I would not want to cruise at the engine's redlne.
That depends on what transmission it is. What engine was it mated to? The only one that will bolt up to the diesel bell housing is is one from a 2.3.
PostPosted: Mon May 16, 2011 5:20 pm
I just looked a little deeper and foud out the bell houseing can not be seperated on the diesel 4x4 trans it is one peice.
PostPosted: Mon May 16, 2011 10:20 pm
Not quite true. You're right, it's not like a regular bell housing. It's the front half of the case. If you are referring to your 4-speed bell fitting on the 5-speed transmission, that's doubtful--but it might fit. It depends on if the bearing retainer (inside the bell housing, behind the clutch fork) has six bolts, or four. If it has six, it will fit. If it has four, it won't. And all this is assuming the new 5-speed is from a 2.3 vehicle.
PostPosted: Tue May 17, 2011 8:52 am
Thanks Jack, It is begining to look like to large of project, and to many veriables I need to know before I even get started.
Bruce
PostPosted: Tue May 17, 2011 9:47 am
I just recently finished my swap. I swapped the factory 2wd diesel 5-speed out with a 5-speed from a turbo Impulse.
PostPosted: Wed May 18, 2011 3:14 pm
I was lucky to pick up a chevy luv shop manual and it has a break down of the diesel 4x4 trany and it shows the bell and about half of the tran all one piece.Are we talking about the same thing?
PostPosted: Thu May 19, 2011 8:31 am
Any one else got any ideas?
PostPosted: Thu May 19, 2011 8:12 pm
Yes, the front half of the case = "bell housing". There should be a metal plate in the middle that's about 1/2" to 5/8" thick. Then there's the rear half of the case.
However, it's about a 50/50 shot that your 4-speed bell housing will mount on a 5-speed transmission. You will know as soon as you remove it, by looking at how many bolts are on the cover plate for the input shaft bearing (the plate that has the pivot ball for the clutch fork). Four bolts, you're outta luck. Six bolts, and you're good.
PostPosted: Thu May 19, 2011 9:06 pm
Thanks for your patiants, It looks like a pretty big project. Where the bell housing meets the trany, at that point It becomes square and is about 12" to 14" more before it seperates.
PostPosted: Fri May 20, 2011 7:26 pm
I'll take a photo of mine when I get home (I'm on a class trip with my 8th-grader right now). Then you can compare mine to what you're looking at.
PostPosted: Fri May 20, 2011 9:35 pm
Thanks Jack,
It is my daily runner and if I swap it out I need to make it work the first time. Any way to tell which trans is needed without droping the whole thing. You know how hard it is to find parts for this thing, I just can't drop the trany and then start looking.
Bruce
PostPosted: Sat May 21, 2011 5:13 pm
Jack,
I found a tranny that fits a trooper,Amigo and roadeo.It has the starter on the corect side. The guy called it an
MUA 5.What do you think?
PostPosted: Mon May 23, 2011 11:13 am
Thanks
