It is currently Sat Mar 21, 2026 12:42 pm
 Post subject: 350 with a 280 cam
PostPosted: Mon Apr 18, 2011 12:16 am
I have a 66 chevy swb. i got a recent rebuilt motor real cheap. has holley intake, holley 600 carb, 202 heads, small cam and bored .30, headers to dual 2.5" 40 series flowmaster dumped at rear.
now im wanting to make it better! i have
Holley street dominator intake
holley 650 double pump
280 'Magnum' Hydraulic Flat Tappet Cam kit (springs, lifters, timing ect..)
im upgrading to a 12 bolt rearend with a posi 373 gears
im wanting to know if the 202 heads would work good with this set up or if you recommend some that would work better that are some what for a good price. as far as i know these heads are stock.
and what would you roughly est hp at?
 Post subject: Re: 350 with a 280 cam
PostPosted: Sat Apr 23, 2011 8:01 am
WHAT ARE THE CASTING NUMBERS ON THE HEADS.ARE YOU SURE THEY ARE 202 VALVES.WHAT KINDA OF PISTONS ARE IN MOTOR. NO MATTER WHAT ITS A CHEVY TRUCK.I VE DRIVEN A 64 SWB FOR 25 STRAIGHT YEARS DAILY
PostPosted: Mon Apr 25, 2011 3:40 pm
Guy 66,
Ran the same combo as your up grade. Then switched to 23 degree trick flow heads and dropped ONE
second in the quarter- 12.80. The next year we went to a mech. lifter cam 0f .570 lift and dropped
another Second - 11.80. Alum. heads make all the difference!
mr.T
PostPosted: Mon Apr 25, 2011 8:08 pm
I wouldnt worry so much about aluminum or cast in your set up. Just get some heads that FLOW. Probably get some iron heads in the 205cc range that will work good for around $700....
PostPosted: Mon Apr 25, 2011 8:32 pm
And ditch the strip dominator intake, if you stay with the hydraulic, an RPM air gap or similar would be a better choice, IMO...
