It is currently Sun Jun 07, 2026 8:18 am
PostPosted: Sun Nov 02, 2003 8:44 am
I pulled my valve cover off yesterday only to find...a snapped off bolt. It's the one in the front right. The little small ones . It's leaking coolant there now , down into my engine . What do ya'll think would be the best way to get it out of there ? I know i will have to pull the head...no problem...but , how do i get the bolt out. Drill it out ? Bolt extactor? Any thoughts on this would be great! :cry:
 Post subject: broken bolt
PostPosted: Sun Nov 02, 2003 11:21 am
I dont know why you have to pull the head. I cant picture the bolt but if you can get to the head, why cant you get it. I would soak the bolt in rust remover stuff. Then you should be able to drill down thru center of bolt with a smaller drill bit and use an extractor to remove it.
Jay
PostPosted: Sun Nov 02, 2003 11:38 am
.......if ya' have ever looked down iside of an 80 models head..you woud see two smaller bolts , smaller than all the rest of the head bolts. Now this is the timeing chain area....and the bolts are about 6'' down inside. The head is still good ...and the head is still alluminum! I'd think that if i can ...take the head off , then i'm only dealing with a steel block....bit safer for my drilling expertese!!>>>I'm thinking though that when i get the head off...there just might be a little-bit of that friggin' bolt sticking up.......so that i might not have to drill. :) Thanks
Last edited by John Schoolcraft on Sun Nov 02, 2003 11:47 am, edited 2 times in total.
PostPosted: Sun Nov 02, 2003 11:39 am
:oops:
PostPosted: Sun Nov 02, 2003 12:41 pm
I hate to say this but I dont know what my head is made of. I have a feeling it is alum but havent had to mess with it. I have adjusted the valves and stuff but dont remember. However I would not be afraid to drill the bolt if it broken off smooth. You can make a center punch mark on the bolt if it sticks up. this makes drilling it very easy. They also sell a drill bit that does not have any teeth (sort of) on the side so it will only drill the pointed end , it wont elongate the hole.
If you do pull the head off, Sears sells a stud remover that works real well. I could explain it however its easier to go to Sears and look at one. I would still hose it down with rust dissolver for several days if you can.
Jay
PostPosted: Sun Nov 02, 2003 5:14 pm
John, try this little trick i learned this summer, if it aint snaped off flush and you can get a pair of vice grips on it:
put some heat around the bolt, not much, a propane torch should work (oxy-actylean is better) then take a candle and rub it around the bolt. the heat will melt the wax and suck it down into the treads lubricating it.
i took out 5 belly pan bolts from a dozer like this....works great :D
PostPosted: Sun Nov 02, 2003 10:14 pm
Thank' s guy's for the thoughts. Sears hardware is just down the road from me 8) Larp i never heard of that before....but i can see where that might work....cool.....thanks... :idea: :idea:
PostPosted: Sun Nov 02, 2003 11:55 pm
wow, i havent heard of that trick either. And hang out whith alot of (dare i say it, red necks) guys who try to find cheaper easy ways of doing things :lol:
PostPosted: Mon Nov 03, 2003 1:26 pm
now, what might i ask is wrong with rednecks? i happen to be one. and im damn proud
Currently no more luv's... But in search of one!
PostPosted: Tue Nov 04, 2003 6:03 am
if the wax doesn't work a left handed drill bit works wonders in some situations.
03Cobra
PostPosted: Tue Nov 04, 2003 7:10 am
Humm... a left handed drill bit....never heard of such an animal.......is it anything like a left handed cigarette.? :lol:
PostPosted: Tue Nov 04, 2003 8:09 am
:lol: .....ummmm....no.
just like a regular drill bit, but the twist goes counter-clockwise. many times the heat and vibration from drilling will loosen the bolt and since the drill is running in reverse the bolt comes out.
*note*....remember to run the drill in reverse.....*cough*someone i know has forgot that before and dulled the shit outta the bit :roll: :oops: :lol:
PostPosted: Tue Nov 04, 2003 3:03 pm
im not bashing on red necks at all, i have been called one before (i dont realy care). I was just saying that i would have expected to know almost all the tricks becouse i hang out whith guys that use the little tricks.
PostPosted: Thu Nov 06, 2003 12:11 am
You know if your a Redneck, if you mow the lawn and find a Luv...
I was wanderin where that one went....
:D
Sweet trick with the wax.. may have to try that one day...
PostPosted: Thu Nov 06, 2003 3:08 am
I've never found one in the lawn, but I did lose one in the field behind the barn. My dad decided to rearrange things on the farm and moved it down in the woods. I went looking through the tall grass for quite a while before I decided I better ask where it went.
Users browsing this forum: Bing [Bot] and 41 guests
