It is currently Mon Jun 08, 2026 7:50 am
Post new topic Reply to topic  [ 656 posts ]  Go to page Previous  1 ... 19, 20, 21, 22, 23, 24, 25 ... 33  Next
PostPosted: Wed Jan 26, 2011 3:50 am
1/4 in fuel line fitting with 1/8 in pipe threads. just put a new one on mine. I got it at AutoZone.
1979 Luv 2wd, rebuilt impulse G200, Weber 32/36, Offy intake, Delta cam, Pacesetter header, Flowmaster, 2 1/4 inch pipe, lowered 4 inches, Bed shortened 10 inches, 1997 Tahoe wheels with 225/50R16 Toyo Proxes.
PostPosted: Wed Jan 26, 2011 4:07 am
So you can use the smog stuff if it is required and with the Offy installed it will be legal for those who have to have it? I don't need to worry about the smog stuff here, but I have had a couple people asking me about it recently.
http://www.purerockradio.net/
PostPosted: Wed Jan 26, 2011 7:11 pm
ctmandu wrote:
most dont have a return line .... but if the hole is there then get a fitting from any parts store ... sorry but dont remember the size...
no problemo. hooked up the new carb today w/o a fuel return wired up the electric choke and it fired right up :ebiggrin idling a little over 2k rpm. still gotta tune it in a little bit but it runs!
PostPosted: Fri Jan 28, 2011 2:52 am
I think so Mokadeth. The Offy had all the smog provisions that my stock intake had.
PostPosted: Wed Feb 02, 2011 5:43 pm
Mokadeth I was wondering if you have any more intakes and how much are they thanks
PostPosted: Tue Feb 08, 2011 6:45 pm
Mokadeth I was wondering if you have any more intakes and how much they were i have a 81 4x4 so would prefer dual plane thank you
PostPosted: Sat Feb 12, 2011 11:15 am
Good news for CA Luv owners for the 76-79. Back in 1986 Redline approach Calirfornia Air Resource Board (CARB) and had them test a kit they had for the Weber to show it would not effect emissons on the Luv.
"Redline, Inc, a distributor of Italian made Weber carburetors, has applied for exemption from the prohibitions of Vehicle Code Section 27156 for the Redline Conversion Kits No. k8602 and No. K8662 using one (1) Weber Model 32/34 DFT9 A or 32/34 DFT11 A carburetor. These Redline Caruretor Conversion Kits are designed to replace the Hitachi Carburetors found on 1972-1979 Chevrolet LUV pick-up trucks with 1.8 liter engines. "
So CA Luv owners 76-79 could buy the offy intake and put the above webers mentioned on there. The article also states there a couple of hoses you can remove. It's a long document (27 pages), but I know it's in there. lol
It sucks for the 1980 though. I don't know why Redline did not include that year.
I asked Redline about a replacment for the 1980 Luv, but the said they had no carburetors for that year that would pass smog. I also submitted the question through SmogTips.com to a smog ref. He said the Carburtetor has to have an OE on the model to pass smog.
Here's the forum Link:
viewtopic.php?f=5&t=24155
Here's the CARB order link:
http://arb.ca.gov/msprog/aftermkt/devic ... 133-13.pdf
PostPosted: Sat Feb 12, 2011 10:56 pm
That's great news for the people who are required to have the smog stuff! I don't see why the 1980 would be exempt, as far as I knew it was the same carb and maybe even the same for the '81 and '82? The Offy would work anyway with the stock carb if you got an adapter or had one fabricated. Offy did used to make an intake for the stock carb and I think I mentioned it in the past, but no one seemed to show any interest. Anyway, that is great news for the people who want to upgrade to the Weber. I still have plenty of the #6204-CW intakes if anyone wants one.
PostPosted: Tue Feb 22, 2011 7:51 am
How much for the offy?
1980 Chevy LUV 4x4 Weberfied Sold
1974 Chevy LUV 4x4 Weberfied
PostPosted: Wed Feb 23, 2011 2:51 am
PM sent.
PostPosted: Fri Feb 25, 2011 11:40 pm
Thank you very much for such a sweet intake I cant to put it on.
PostPosted: Mon Feb 28, 2011 10:42 pm
Glad you received it ok and I hope you are happy. I am sure your truck will be happy with the upgrade!
PostPosted: Sat Mar 05, 2011 12:52 pm
how much?
PostPosted: Sun Mar 06, 2011 12:42 am
PM sent with info.
PostPosted: Mon Mar 14, 2011 10:29 pm
Finally got my Offy installed this weekend.
Even given that I have yet to properly tune my Weber to this altitude,
the improvement was pretty dramatic. (I got the dual plane version)
I would not say it had a major increase in actual net horsepower, (Which I largely attribute to the tune on the carb), but it has horsepower where it never had it before! 8O
Both in the bottom end, and the top end.
It felt like it actually was trying to break the 215/75/15's loose a bit off the line,
And it required only 1/8 inch of pedal to maintain 55mph, whereas I would have had my foot in it before.
VERY HAPPY!!
Image1980 4x4, 3" body lift, G180/G180 head, Pacesetter header, Offenhauser Dual Port Intake, Weber 32/36, Electronic Ignition, Glasspack & a Smokestack.
PostPosted: Mon Mar 14, 2011 11:02 pm
Glad you are happy! I don't know the feeling yet as I haven't had mine installed yet, but based on all the positive comments I am sure I will be happy someday as well. I am beginning to wonder if the dual port is the intake to have instead of the #6204? I seem to have had more requests for those lately, but I didn't have many made. Maybe next time around I will get more of the dual port made if enough people are interested.
PostPosted: Wed Mar 30, 2011 5:18 pm
Im a newby here and Ive yet to read through all he things needed to make the best of this mod but I would be interested to know the pricing.
PostPosted: Fri Apr 01, 2011 12:00 am
PM sent with info and welcome to the fourms!
PostPosted: Mon Apr 04, 2011 4:18 pm
i might be interested in one too in the near future. working on a performance g180 build with my spare.
PostPosted: Mon Apr 04, 2011 6:10 pm
I believe I sent you a message a month or two ago. Just let me know when you are ready for one as I still have the #6204-CW in stock.
