It is currently Sun Jul 05, 2026 10:38 am
 Post subject: weber fuel return????
PostPosted: Sat Jan 29, 2011 1:44 pm
alright...... really dumb question... so if i was to hook up a fuel return to my new weber 32/36 where the heck would i be hooking it up! its a brand new weber. it has a fuel inlet on either side at a 45 degree angle on top of the float bowl, and has one other hole under those two thats bigger diameter.
so would i just hook up another fuel fitting to the other 45 degree fuel inlet or where does it go??? i dont want to let it build back pressure in the line when its sitting at an idle in traffic.
and i figure the fuel pump is designed to run at all times and with no fuel return line its going to try to keep flowing.
any information on the subject would be appreciated. such as.... where to find the fuel return fitting and where the heck to put it!!!
PostPosted: Thu Feb 03, 2011 5:23 pm
There is no return fuel line for the Weber. Hook the fuel line from the fuel tank to the Weber and the old return line needs to be blanked off or the fuel will siphon its way back from the tank.
The fuel pump will stop after it reaches it's working pressure.
You can install a fuel pressure regulator and adjust it to 2psi for better fuel and float control.
Part#31800.063.
The only dumb question is one that hasn't been asked.
We're all here for a good time, not a long time.
1979 LWB 2WD G180 Weber 32/36 Turboflow Exhaust
1979 LWB 2WD G180 Stock Mikado
PostPosted: Thu Feb 03, 2011 5:51 pm
I'll look tomorrow on one of mine that I have a return line on and I think it hooks up to the larger outlet under the two up top and it will make your pump last longer.
PostPosted: Thu Feb 03, 2011 8:50 pm
i hooked my fuel return up to the other fuel inlet with a 90 degree fitting angled upward a bit so lines level is higher than the float bowl to keep my fuel from going in one end and out the other. not sure if thats the ideal spot but it seems to be working
PostPosted: Fri Feb 04, 2011 1:57 pm
okay got it figured out...
the throttle was being held a bit too far open and the timing was a bit off. so even when the adjustment screw was out of contact the gas was still being opened. intake had a LAKE of gas in it so i let it burn that off and got it all adjusted and did the timing by ear till i can get ahold of my dads timing light. :ebiggrin :lol: truck flys now :twisted:
thanks everyone who gave me tips on getting it fixed :!:
PostPosted: Fri Feb 04, 2011 4:52 pm
ANDDD i was wrong :evil:
it was doing alright. stopped and parked. engine cooled down. and now it wont even start and idle. no idea what is wrong now, getting REALLY sick if this crap.
PostPosted: Sun Feb 06, 2011 4:38 pm
I'm running mine on the stock pump with a regulator set at about 4 psi and no return line. You might try that.
1979 Luv 2wd, rebuilt impulse G200, Weber 32/36, Offy intake, Delta cam, Pacesetter header, Flowmaster, 2 1/4 inch pipe, lowered 4 inches, Bed shortened 10 inches, 1997 Tahoe wheels with 225/50R16 Toyo Proxes.
PostPosted: Sun Feb 06, 2011 10:00 pm
I installed a fuel filter that had a single inlet and a dual outlet. Round steel Fram I think. I hooked the return to the extra outlet, and it works great. Except it will siphon back and not start after sitting more than a week. But as long as I fire it up at least once a week, it's fine.
Users browsing this forum: Baidu [Spider] and 28 guests
