It is currently Fri Jun 26, 2026 3:13 am
PostPosted: Wed Dec 08, 2010 6:14 pm
I bought a set of cadillac escalade wheels to put on my 1980 chevy luv. They bolt up just fine but the hubs on the front stick out too far to get the center caps on. I see lots of pictures with these same wheels on luvs so i know there is a way. Wheels spacers? But then can i still lower it? Different hubs or some kind of conversion kit. Any ideas help.
PostPosted: Wed Dec 08, 2010 9:23 pm
On the '81 and later LUVs/P'ups, folks bore out the centers. I don't know what the do to cover the hub after that.
PostPosted: Sat Dec 11, 2010 8:50 pm
Most people who run centercaps in the front with escalade wheels have to remove the dust caps, and run without the caps. If you could seal the center cap up enough you could get away with it.... Personally I wouldn't run them like that for a lot of reasons, but thats pretty much the only way to run them without adding wheel spacers to clear the dust cap.
1975 V8 Luv
1980 Bagged Luv
PostPosted: Sat Dec 25, 2010 10:48 pm
I have 97 Chevy Tahoe wheels on mine and I used 1/4 inch wheel spacers to make mine fit. $9.99 ea at Pep Boys. the spacers bring the wheel out just past the flange in the wheel hub. just an idea.........
1979 Luv 2wd, rebuilt impulse G200, Weber 32/36, Offy intake, Delta cam, Pacesetter header, Flowmaster, 2 1/4 inch pipe, lowered 4 inches, Bed shortened 10 inches, 1997 Tahoe wheels with 225/50R16 Toyo Proxes.
PostPosted: Sun Dec 26, 2010 5:27 pm
Nice, i appreciate the help guys
PostPosted: Wed Jan 05, 2011 1:17 pm
i got escalade rims on my 76 luv. i just took the dust caps off and grinded down the spindle bolt. havent had any problems.
Users browsing this forum: Baidu [Spider] and 30 guests
