It is currently Tue Jul 07, 2026 12:45 pm
 Post subject: fuel pump compatibility
PostPosted: Mon Nov 01, 2010 11:38 pm
is there any reason this wouldnt attach to my 79 mikado just fine?
my fuel pump is going out, and this seemed like a good match for my quadrajet (5psi)
thoughts?
PostPosted: Mon Nov 01, 2010 11:50 pm
hhhaahahaha forgot the link. woops.
http://www.summitracing.com/parts/CRT-P4600HP/
PostPosted: Tue Nov 02, 2010 12:29 am
don't see why not. the most important thing to remember is the fuel flow rate and the delivery pressure.
PostPosted: Tue Nov 02, 2010 12:52 am
fuel flow rate is high. 100 gph. and everything ive read is says q-jets only want at max 5 psi.
i didnt think it would be an issue. but id rather not spend 100 bucks to find out :o
PostPosted: Tue Nov 02, 2010 4:33 am
I have been running a cheap little after market Purolator for 5-10 years with no problem. Others have reported similar results with generic fuel pumps. I would see what your local autoparts store stocks.
PostPosted: Tue Nov 02, 2010 11:13 am
that fuel pump is fine but overkill.
if your not racing then a 30 dollar clicker pump from vato-zone would do fine as well.
A.j.
PostPosted: Tue Nov 02, 2010 2:06 pm
ahhh. it is overkill now i agree. i picked up a v8 that ill drop in in a few months. is it still overkill? its going to be a mild mild..
PostPosted: Wed Nov 03, 2010 8:53 am
for the most part, it would be overkill for a mild to stock v8 in a luv. case in point, the sorry stock luv pump held out quite well deep into the 13s for me on a v6.
But it doesnt hurt to "over pump" when having some performance goals. increasing the line size with the stock or small pump really helped alot too. a 3/8s line is alot of stored fuel for a WOT blast. and in a truck as light as the luv, a good blast is moving along purdy fast... so you wont be in it for an extended amount of time.
this pump is cheaper and more than enough for a mild V8
http://www.summitracing.com/parts/CRT-P4070/
A.j.
Users browsing this forum: Baidu [Spider] and 90 guests
