It is currently Tue Mar 24, 2026 10:57 am
PostPosted: Fri Sep 03, 2010 4:52 pm
long story short i am putting the luv truck back together stock and just ditching the v8 attempts for now (lack of funds)
anyway the stock engine and trans im picking up here in a week or two has the emissions stuff deleted .. which is fine for Missouri, but not CA.
what all do i need to do to get it to pass cali smog, short of putting the smog pump back on and keeping the egr. will i have to install a cat on a truck that never came equipped with a cat?
any and all advice/tips would be appreciated so that i can get the truck plated when the time comes in California
Kyle
PostPosted: Fri Sep 03, 2010 7:53 pm
You have to have all the emissions equipment that came with the truck originally. That includes the stock carb, Weber won't pass. CA is the toughest state for smog. No, you won't have to add a catalytic if the truck didn't come with one originally. Everybody has to have all the equipment, but some years are not subject to inspections.
PostPosted: Sat Sep 04, 2010 8:59 am
thank you very much. ill be getting the truck running and plated here. but then i will collect all the smog parts i need for the truck.
the offy intake doesnt affect smog, does it?
i just checked online, 75 and older are exempt. anyone wanna trade my 1977 for your 1975 or older? :lol:
PostPosted: Sat Sep 04, 2010 7:58 pm
Technically the Offy would require an Executive Order (EO) number from the California Air Resources Board (CARB). That said it may depend on the inspector you see, whether or not he notices it's a different brand and if it still has the emissions fittings you may be in better shape.
PostPosted: Sun Sep 05, 2010 12:13 am
hmm .. ill just put it all back to stock according to 1977. and then ill just go from there as far as modifications.
is there information on motorswaps anywhere on the CA DMV website? i wasnt sure what i was looking for. or is there another site where i can gain information? my search hasnt turned up anything valuable
PostPosted: Sun Sep 05, 2010 4:34 am
How to do a California legal EFI engine swap
viewtopic.php?f=6&t=22153&start=0
PostPosted: Sun Sep 05, 2010 7:07 am
:oops: never thought to even search that topic here. my mistake
PostPosted: Mon Sep 06, 2010 12:26 pm
Not a Cali guy, but I do not think a non Cali car-truck is legal unless you get a ???? referee to give it a exemption.
luvv8 should be able to let you know about this, not that the other guys do not know. If he does not reply, send him a pm
PostPosted: Thu Sep 30, 2010 2:41 pm
There are basically two sets of smog setups.
Vehicles that were delivered in ca usually had more smog systems on them.
The other 49 states used Federal regs which were somewhat more lax.
If you have a federal vehicle, should be a sticker under the hood, if its still there.
When bringing in a fed vehicle ca usually only requires the smog as required by fed rules.
Some vehicles had the same smog, fed and ca.
Determine where the vehicle was first sold and what smog you'll need.
PostPosted: Thu Sep 30, 2010 9:37 pm
well i have original paperwork from the dealership. it was sold here in missouri. ive never heard of the city (and im not sure where i put all my luv truck papers .. or i would just go look). but as far as i know the truck has been in Missouri its entire life
PostPosted: Fri Oct 01, 2010 10:25 am
Then check and see what smog was originally on it. Ca should not require any additional equipment.
PostPosted: Fri Oct 01, 2010 9:56 pm
awesome. thank you sir
