It is currently Thu Jun 25, 2026 5:07 am
PostPosted: Mon Sep 20, 2010 9:17 pm
The previous owner of the truck took everything apart to paint but didn't leave any of the washer stuff, does anyone know how or have pictures of how it pumps and hooks to the harness? I did find the fluid reservoir at the junkyard, but nothing else.Thanks.
TUFFLUV
PostPosted: Wed Sep 22, 2010 8:43 am
the res bottle should have a small electric pump that sits between the bottle and the bracket where it sits. i will take crappy cell phone pic later today, and since im sure you don't have the luv WW pump, i will take a look for one while at work today. i will post results when my shift is up.
PostPosted: Fri Sep 24, 2010 9:07 am
I now have all the parts to the washer system but the plug to the harness I see for all of the other trucks is gone on mine.Unless it is located somewhere else?
Image This one is behind the carb...
Image there is a red green with quick connects on the far right here...
TUFFLUV
PostPosted: Fri Sep 24, 2010 2:14 pm
My 77 has has a 2 wire plug hanging down just inboard of the reservoir, blue and blue/white. Likely the one to the right in your picture.
PostPosted: Fri Sep 24, 2010 5:27 pm
ThATS what i assumed, i looked for it all along the harness but no blue and blue/white. that plug to the right has a red and green wire im thining used to attached to the cali carb...
TUFFLUV
PostPosted: Fri Sep 24, 2010 5:37 pm
also the one beid the carb wont reach the motor and had no power to it.. th wires on that one are light breen and red.
TUFFLUV
PostPosted: Fri Sep 24, 2010 8:02 pm
The blue wire comes from the fuse and should be hot when the ignition is on. The blue/white goes to the the switch, and is grounded when the switch is on.
PostPosted: Fri Sep 24, 2010 8:26 pm
i unersand that and tested thm with the ignition on and running, but there inst a plug to fit the washer motor where all the other ones are on the luvs...
TUFFLUV
PostPosted: Fri Sep 24, 2010 9:18 pm
Sounds like you will have to run new wires. Solid blue from fuse #7 to the stem of ''T'' shaped plug. Then blue/white from the cross bar to the switch.
PostPosted: Mon Sep 27, 2010 1:17 pm
Thats what i was going to do, just didnt know if there was a little "trick" i was missing or something. Thank you sir.
TUFFLUV
Users browsing this forum: No registered users and 72 guests
