It is currently Mon Jun 08, 2026 12:02 am
Post new topic Reply to topic  [ 85 posts ]  Go to page Previous  1, 2, 3, 4, 5  Next
 Post subject: Re: bagged 74 luv
PostPosted: Wed Sep 08, 2010 6:47 pm
i'm not big on bagged trucks but i can definitely appreciate hard and good work.keep going
luv less for the time being
PostPosted: Wed Sep 08, 2010 10:57 pm
Hey thanks for the support. It means a lot. I got it started today and I can't stop smiling. I'm so motivated to get this done. Can't wait to drive it
PostPosted: Thu Sep 09, 2010 12:25 am
i know that feeling. great to build some thing with your own hands and see it work.
PostPosted: Thu Sep 09, 2010 9:30 pm
Well a few posts back a talked about "triangulating" my lower control arms and there were some questions about it. So today I did a Lil work on them and here's what I came up with so far. Not done yet.
First I started with a small piece of 1/8 inch plate and welded it to the arm where the new piece of the arm is going to connect
Then I lined up the pivot points on the original arm and the new piece I am adding with a piece of 1/2 inch all thread. Both pieces of the arm must pivot in a straight line together as one or the arm will bind throughout travel
Then go ahead and weld them up with the all thread still going through both pieces. I will post pics of the brackets I am putting on the frame for the new piece tomorrow
PostPosted: Fri Sep 10, 2010 10:42 pm
Got my drive shaft finished
PostPosted: Sun Sep 12, 2010 9:57 pm
2 1/4 inch body drop to flat rocker. No pinch.
Tight fit much?
Lays hard
PostPosted: Sun Sep 12, 2010 10:11 pm
Dude, what do you do for your day job?
Great work. 8)
PostPosted: Sun Sep 12, 2010 10:30 pm
I manage an auto part store
PostPosted: Mon Sep 13, 2010 5:49 pm
im still learning about bodydrops .. did you do stock floor or traditional?
PostPosted: Mon Sep 13, 2010 7:03 pm
traditional. stock floor would be if i replaced the frame rails with something not as tall. i cut my floor and raised it. i didnt go stockfloor because i want as much room ander the cab as possible for mufflers and stuff
PostPosted: Wed Sep 15, 2010 10:12 am
Well I needed new tie rods for my truck and called moog and they no longer manufacture or carry tie rods for the luv. So I started checking out some tie rods from different vehicles for same length and taper. I found out that 68 through 74 chevy nova tie rods work perfect.
Inner is a moog#es681n
Adjusting sleeve #es350s
Outer#es381r
PostPosted: Wed Sep 15, 2010 10:43 am
Working in a parts store sure helps. 8) This is useful information to have.
PostPosted: Wed Sep 15, 2010 4:01 pm
agreed .. great info to have on the tie rod stuff
PostPosted: Wed Sep 22, 2010 6:15 pm
Almost done
Picked these up cheap. Pathfinders
PostPosted: Thu Sep 23, 2010 3:53 am
1lowluv wrote:
Almost done
NICE 8O its seeing pictures like these that make me want to go start the build on my luv :lol:
PostPosted: Mon Oct 04, 2010 10:34 pm
Good new and bad news! The good news is that the truck is looking awesome. The bad new is that even though it looks awesome the engine blew up. So I just started on another engine. Hope to have it done by the end of the week. And I got a new intake manifold since mine was a Lil taller than I liked
PostPosted: Tue Oct 05, 2010 7:01 am
well that bad news sucks :evil:
PostPosted: Wed Oct 06, 2010 11:18 pm
New manifold on my new engine
PostPosted: Sat Oct 23, 2010 9:32 pm
Well it's pretty fast. Runs great! I'm stoked
PostPosted: Sat Oct 23, 2010 9:55 pm
looks good :ebiggrin :ebiggrin
