It is currently Fri Mar 27, 2026 7:33 am
 Post subject: cold natured
PostPosted: Mon Oct 06, 2003 12:52 pm
i have an 81 2.2 81 diesel. and its very cold natured, how do u get them started in the winter? any tricks? some people say starting fluid,some say no. thanks in advance
PostPosted: Mon Oct 06, 2003 1:40 pm
starter fluid shoould work. all the deisels at my work need a 1 to 2 second squirt into the intake.
PostPosted: Mon Oct 06, 2003 1:59 pm
I would not put starting fluid in any smaller diesel engine. Some of the larger motors are OK with it, such as construction equipment. But I've seen a small squirt of starting fluid blow the head gasket on a small automotive diesel.
Make sure your glow plugs are working properly. If your having trouble, you may have one or more that aren't working.
PostPosted: Mon Oct 06, 2003 2:03 pm
I heard that the starting fluid distroys the engine, and they become addicted to it. My brother had a diesel rabbit and had to use starting fluid in the summer just to get it started. On both of my diesel trucks I just plug them in at night via the block warmer, I use a timer switch (the cheap kind that you would use to turn on your house lights while you are away from your house for an extended period of time) If your truck does not have a block warmer, you can pick them up for under $20 at JC whitney or most auto parts stores.
BTW did you check out the new diesel forum on the main LuvTruck page?
1981 Chevy LUV 4x4 2.2L Diesel 4 Speed Selling out moving over to VW TDIs.
PostPosted: Mon Oct 06, 2003 2:19 pm
Whats wrong with just putting new glow plugs in.
l have had no trouble starting my diesel LUV's no matter how cold it is.
PostPosted: Mon Oct 06, 2003 5:13 pm
The block warmer is a good idea, but is there anyway that you can use a block warmer on it without actually plugging it into an outlet? Maybe an extra battery or something else? Do you know of something like that, because my truck is my work truck and I work nights.
 Post subject: cold starting
PostPosted: Tue Nov 11, 2003 11:25 pm
I am a huge fan of battery warmers. They are easy to install and the added warmth gives you more cranking power. They still also have magnetic block heaters that you just slap on the oil pan (they usually fall off when driving)
PostPosted: Tue Nov 11, 2003 11:27 pm
also if you have a manual tranny, thin down the gear lube in the tranny. 80-90 gear lube gets real thick in the cold.
