It is currently Tue Mar 17, 2026 10:38 am
Post new topic Reply to topic  [ 1122 posts ]  Go to page Previous  1 ... 22, 23, 24, 25, 26, 27, 28 ... 57  Next
 Post subject: Re: LUV II
PostPosted: Tue May 04, 2010 10:24 pm
wow 8O 8O 8O 8O 8) 8) 8) :ebiggrin :ebiggrin :ebiggrin awsome tear to my eye lol
75-luv mikado-V8 350 soon
PostPosted: Wed May 05, 2010 8:49 pm
LSX LUV Owner
control arms welded, and painted. bought new bushings for LCA's. they will be here friday.
rear setup with limiting straps back on.
PostPosted: Thu May 06, 2010 7:52 pm
LSX LUV Owner
PostPosted: Fri May 07, 2010 5:35 pm
LSX LUV Owner
PostPosted: Wed May 19, 2010 10:42 am
LSX LUV Owner
no more interest? lol
return line
drilled and tapped fittings for gauge line fitting
posi clutches and tranny cooler should be here today.
axles, bearings and wheel studs from moser, and walbro fuel pump should be here friday.
and gear install kit.. not sure when it will be here.
PostPosted: Wed May 19, 2010 2:44 pm
lookin nice.
any chance you could get a few pictures close up of the front bags and how you mounted them? im just trying to figure out how i wanna bag mine. thanks.
PostPosted: Wed May 19, 2010 10:20 pm
LSX LUV Owner
look a page or so back. i got pics of everything.
PostPosted: Thu May 20, 2010 5:10 pm
Well, I was on board until you drilled and tapped that fitting...
PostPosted: Fri May 21, 2010 3:58 am
Why, it is just a guage outlet..??
PostPosted: Mon May 24, 2010 11:19 am
after looking at my truck and reading this thread ... what is #1 in this picture. #2 is the sway bar, correct?
PostPosted: Mon May 24, 2010 12:18 pm
1 is the sway bar, 2 is the rod that holds the lower control arm from shifting back and forth.
PostPosted: Mon May 24, 2010 1:53 pm
On a Mustang II front end that would be called a stabilizer bar .
PostPosted: Mon May 24, 2010 7:26 pm
LSX LUV Owner
yep...
got out there real quick and cut one bracket up and drilled two holes in it. ill have to end up welding the brackets on because the two holes only have about 1/16" before it breaks through the caliper bracket. gonna work out pretty good though. gonna take that bracket off tomorrow and copy it to other bracket and get it all cut out and maybe get them welded in.
PostPosted: Sat May 29, 2010 9:32 pm
LSX LUV Owner
blahhhhhh.
PostPosted: Sat May 29, 2010 9:59 pm
PostPosted: Sun Jun 06, 2010 11:56 pm
This build is so cool! Thanks for keeping all of us in the loop on your progress. It gives me a lot of inspiration for my build. Working on it a lot more since the weather got better. Keep up the good work!
Ben
Ben
1975 Luv, Street-Strip Build: in progress
PostPosted: Mon Jun 07, 2010 5:13 pm
LSX LUV Owner
sweet!!
its just been collecting dust.. might order the braided brake hoses tomorrow..
PostPosted: Mon Jun 14, 2010 6:44 pm
LSX LUV Owner
one light coat.. used one of the four bottles. gonna do another coat tomorrow. says a one hour flash time, itll be dark by then..
gonna spray it on heavier tomorrow
PostPosted: Mon Jun 14, 2010 7:36 pm
Looks good.... which spray liner exactly are you using?
PostPosted: Mon Jun 14, 2010 7:56 pm
LSX LUV Owner
thanks, im using a u-pol raptor kit. came with a gun and everything. real simple to spray
