It is currently Mon Feb 02, 2026 7:10 pm
 Post subject: master cylinder's
PostPosted: Fri Apr 09, 2010 11:58 pm
what is every one using. i need to change mine and was thinking of switching to a newer MC from 87-91 isuzu will this work. on the stock booster? our should I get a new stock MC?
1975 luv daily driver.
Project-soon to be revived
 Post subject: Re: master cylinder's
PostPosted: Sat Apr 10, 2010 8:19 am
I was able to get a new, stock one at Pep Boys a few years ago.
PostPosted: Sat Apr 10, 2010 9:18 am
Bought mine at Napa
PostPosted: Sat Apr 10, 2010 2:11 pm
ya I am going to get a new stock one. just was woundering about more of a stoping power when I change engines for my project truck. i might go with a v8. but thanks just going with a stock.
PostPosted: Sat Apr 10, 2010 4:19 pm
Many with V-8 trucks including me find the stock set up fine.
PostPosted: Sat Apr 10, 2010 7:25 pm
Does your brake booster fit OK? I'm going to put front discs on mine, and since I have a hydraulic clutch I am afraid a larger booster from the later disc brake master cylinder/booster combo will have interference with the clutch master cylinder. Now, I do have a smaller booster on my 72 now (stock) but I am assuming that will crap out one day, and I haven't been able to find a replacement for that one smaller one anywhere.
Also, what about just running manual brakes? Like with a Corvette manual brake master cylinder? Also, I heard there were S-10s with manual brakes. If they ran front disc rear drums with manual brakes, I think I'd be fine with that.
That said, everyone on here uses the stock ones with a booster so maybe that should be a lesson to me.
PostPosted: Sat Apr 10, 2010 9:15 pm
still havent put on those discs eln?
PostPosted: Sat Apr 10, 2010 9:48 pm
The way I look at it is why reinvent the wheel.
PostPosted: Sun Apr 11, 2010 10:06 am
Aluminum master off of a 94 Jeep Cherokee Even working on 4 wheel disc.
PostPosted: Sun Apr 11, 2010 5:41 pm
Running a m/c with out a booster never sat well with me. but with the right bore size it works. well was haveing problems with changing my brakes becuase the ones I got off ebay didnt fit right do to the metal tab the keeps it in place. so im eventually change the lug pattern to 5lug and new calipers along with a new master and booster. think I got a plan :smt017
PostPosted: Sun Apr 11, 2010 10:59 pm
No, I don't have a master cylinder or a newer booster. I should have gotten yours but I ran out of time, and it looks like you needed it anyway so there you have it. I may just use a new disc/drum master cylinder (they are only like $40) with the small booster I already have.
True that...now if I can just fine some damn Luvs in a junkyard near me to get a good deal on parts.
