It is currently Mon Jun 29, 2026 2:23 am
 Post subject: Driveline issues
PostPosted: Mon Feb 15, 2010 9:11 pm
The 4X4 was shaking like crazy. The rear u joint was visually bad. I replaced both. It (on the jack stands) is still shaking when coasting with the clutch in. The is, what I think, is excessive play in the diff.
I'm thinking of just taking it to a shop and have them deal with it.
I think it needs the shaft balanced and the diff rebuilt. Ho hum. It's only money, right?
 Post subject: Re: Driveline issues
PostPosted: Mon Feb 15, 2010 9:35 pm
crap man, that sucks. hope it's not too expensive.
i'm dealing with the thing i SHOULD have done while i was down in LA. That's flushing the brake lines and rebuilding the wheel cylinders..
PostPosted: Mon Feb 15, 2010 9:59 pm
If the drive line is out of ballance it will shake even with the clutch in. As old as these trucks are I would not replace the u joints without a balance, if its out may as well do it one time.
PostPosted: Mon Feb 15, 2010 10:11 pm
A lot of play in the diff can let it wobble as well...
PostPosted: Mon Feb 15, 2010 10:36 pm
OK. So before I take it anywhere, I'll have the drive line balanced and try it out. Maybe the rear is ok.?
PostPosted: Tue Feb 16, 2010 12:00 am
If the rear diff is so worn that it will let the driveline wobble you should be able to see it doing that while on Jack stands. Put a mark on the drive shaft and a mark straight above that one on the bottom of the truck and see if there is a variance (wobble) when it spins. It might not be much but you should be able to see it.
2005 Silverado 3/4T Crew Cab
1981 Luv 2WD
1995 Roughneck JetBoat
1981 Luv parts trk
PostPosted: Tue Feb 16, 2010 8:50 pm
Before you spend much time and trouble try this--disconnect the driveline at the rear, turn it 1/2 turn and reinstall it again.
Many or these have to go back into the yoke the exact same way as they are balanced as a unit at the factory. Costs nothing and worth a try.
PostPosted: Tue Feb 16, 2010 11:13 pm
:ewink Will do. Thanks.
PostPosted: Fri Feb 19, 2010 11:25 pm
Put in new u joints, and ran the truck on jack stands. No good. Had the drive shaft balanced at O.C. Driveline. $45 bucks 1 day! I will install it tomorrow, if the rain stops.
I seem to have what I think is too much slop in the diff. What do you guys think about me just giving the pinion nut a 1/4 or 1/2 a turn and take out some slop before I put the shaft back in? Good idea? Bad idea? I know they should be set with a micrometer while on the bench and all, but this is just to take up a little slop, you know?
PostPosted: Sat Feb 20, 2010 12:57 am
Install the balanced driveline then drive it. You may find all is well.
PostPosted: Sat Feb 20, 2010 10:28 am
Contact:
The Gear Shop
Differerential Specialist
15709 Paramount Blvd
Paramount,Ca 90723
562-634-1396
He can answer any questions you have on your rearend. Great DIY place or bring him the center and he can do it for you.
PostPosted: Sun Feb 21, 2010 12:06 am
Cool. Thanks for the help.
I put the drive shaft in..... no vibes anymore. I took it back out and gave the pinion nut about 1/3 of a turn. It's better now. less clunk between go and coast now. put the shaft back in and all is well now.
PostPosted: Sun Feb 21, 2010 1:35 am
I hope you staked that pinion nut to the threads after tightening, if not it will shortly loosen back up.
Users browsing this forum: Baidu [Spider], Bing [Bot] and 69 guests
