It is currently Mon Jun 08, 2026 12:37 am
Post new topic Reply to topic  [ 24 posts ]  Go to page Previous  1, 2
 Post subject: Re: No Reverse
PostPosted: Tue Jan 19, 2010 8:45 pm
Just roll around under there a look for a trouble spot. Follow the back up light switch wires from the trans. to wherever they go and see what you find. I would think there is a plug somewhere. Flashlights and mirrors help for tight spots.
PostPosted: Thu Jan 21, 2010 4:12 pm
If it only blows when the trans is in reverse it has to be a short somewhere between the switch and the backup lights. From the wiring diagram I don't see anything on that circuit after the switch except the lights. It could be the switch grounding out internally but I'd suspect wiring.
There should be plugs on the two wires going to the switch about 2 inches from the switch on the trans. There are two switches, the reverse switch has red wires going to it. The wiring diagram isn't clear enough for me to tell, but it looks like the red/blue stripe wire is to the lights, and the red/black stripe is from the fuse box. If you disconnect just the red/blue stripe wire and it still blows the fuse then it would be a bad switch, if not then there is short somewhere in the harness connecting to the bed back towards the lights. Another confirmation of it being a bad switch is if the fuse doesn't blow and the lights come on when you connect both wires together. I'm guessing you will have to trace the wire coming from the backup lights through the bed harness and back to the switch. Somewhere in there will be your short if its not the switch.
My 79 had wiring issues all over it when I bought it due to a cooked main alternator wire in the big harness bundle going across the firewall. It shorted to the wire between the reverse switch and the fuse box and the truck wouldn't shut off with the key any more. The alt wire was feeding power right from the bat into the reverse light circuit and also back into the fuse box. That switch is on the same circuit of the fuse box as the coil I believe, fuse blows=no spark=truck dies. It took a couple hours of unwrapping the harness and looking things over to find it but it wasn't too complicated.
PostPosted: Mon Jan 25, 2010 7:07 pm
What would be the best way to get to the revse switch? Takethe engine out or take the tranny out? Just the tranny?
2006 GMC Sierra 2500 HD
PostPosted: Mon Jan 25, 2010 8:41 pm
It should be on the left (drivers) side of the trans. You should be able to get to it without removing anything. It's a round doohicky with 2 wires coming out of it. It's up high near the top of the trans. Once you find it, you should see where to diconect it and get a test light on cont. tester and start diagnosing.
