It is currently Thu Jul 16, 2026 3:17 pm
 Post subject: Went to the track!
PostPosted: Sun Oct 11, 2009 10:57 pm
And it was crap... First time i tried it, the brakes were not holding. Just went through to check everything out. Tried to make a second pass, gonna spray it that time. Nope... Had a few leaks on the system, got those sorted out. Fired up the LUV and turned the system on, and HOLY (*&^%. Not sure what is stuck, but it was hitting the juice all by itself. (It is on a throttle switch, shouldn't do that) Took that as a sign to call it a nite. On a good note, it seemed to like the dope...
 Post subject: Re: Went to the track!
PostPosted: Mon Oct 12, 2009 2:35 pm
http://www.getinthelights.com/racevideo/canton.html
PostPosted: Mon Oct 12, 2009 8:19 pm
Them damn bugs :evil: ....glad you got to go though...looks like the track needed some prep....is it asphalt the hole way?
PostPosted: Mon Oct 12, 2009 8:29 pm
Pretty much. I generally hook good there though. The issue was with the brakes. I tried to do a burnout, and it was pushing it. What looks like more wheelspin partway through was actually me letting off the brakes and mashing it...
PostPosted: Mon Oct 12, 2009 8:52 pm
I see....our track thankfully is cement the entire 1/8 mile...and i hate the pushing problem been working on getting enough vacumm to get my booster to work..
PostPosted: Mon Oct 19, 2009 7:08 pm
"Nitrous is like a hot chick with an STD you cant wait to nail it, but are scared of the consquences." - luvit80. hahaha i love that..
anyways.. im new to racing and was wanting some advice on my truck.
we are planning on running a 400-500hp motor, powerglide tranny, and ford 9in rear.
at our track it seems that everyone uses latterbars on there luvs. is that the best way to do it?
PostPosted: Mon Oct 19, 2009 7:19 pm
This is only my opinion. If you run at more than one track, ladder bars are more consistent, 4 link is MAYBE a little quicker, but you have a tendency to have to readjust for each track. However, at that power range, you should be fine on the stock leafs...
PostPosted: Mon Oct 19, 2009 10:53 pm
I agree...I am at about that power range...stick with leafs and slappers....atleast until you get the virus and want to go faster and starting adding hp.....sticking 500hp with a small slick or drag radial should be no problem...
PostPosted: Wed Oct 21, 2009 7:25 pm
alright sweet. were going to be running pretty big tires. thats what were thinking atleast. what do you think about sizes?
PostPosted: Wed Oct 21, 2009 7:54 pm
slick or drag radial?
