It is currently Mon Feb 16, 2026 2:57 am
PostPosted: Wed Oct 07, 2009 10:43 am
Hi all -
I'm a newbie here, and I have a fairly simple question.
I just bought a rust free, garage kept, 1-owner, 91k mile 1979 Luv, and it starts, runs, and drives great. However, I have what appears to be some timing chain noise up front. It sounds like chain noise and is loud enough to be audible when you're close enough to touch the front fenders of the truck. I need to replace the tappet cover gasket, which I'm going to do this weekend, and I'll check for obvious tension problems then.
I used to own a B2000 Mazda, and it's chain was a bit noisey, which was normal for that truck. How much noise is to be expected on these Isuzu engines?
Thanks in advance.
PostPosted: Wed Oct 07, 2009 2:01 pm
i have never heard a timing chain make a noise, unless i have lived a sheltered life, i dont think its timing chain.
whats it sound like?
zyanug
76 fleetside 350hp 1968 327cu
___/__l____
[_@l__l__@_]***
TILTED wrote:
Boobies!!!!! 8O
PostPosted: Wed Oct 07, 2009 2:43 pm
Timing chains can indeed make noise if they've somehow worn out one of the guides or if the tensioners have gone bad. I just wanted to get an idea of how much noise is 'normal' for the Isuzus without tearing apart the front end of the engine to inspect the guide and tensioners. My little 2.0 Mazda had a small bit of chain noise, but that was normal for those trucks.
PostPosted: Wed Oct 07, 2009 2:49 pm
Welcome to the site. I would think if you can hear the chain rattle then it is severely LOOSE/WORN and would need to be replaced.
I would adjust the valves before I replaced the timing chain, tensioner and slides. If you're replacing the valve cover gasket you are already there so you might as well adjust them. Keep us posted.
2005 Silverado 3/4T Crew Cab
1981 Luv 2WD
1995 Roughneck JetBoat
1981 Luv parts trk
PostPosted: Wed Oct 07, 2009 2:59 pm
Will do. Once I have the tappet cover off I think there will be enough space to shine a flashlight down into the timing cover and see if anything obvious is awry. If the chain needs changing, I'll probably do it this weekend if the parts store can get the stuff in time. As far as I can tell, it's not valve train noise, but I'll take a look once I'm in there.
Thanks for your help.
PostPosted: Wed Oct 07, 2009 3:37 pm
yes if you can hear it replace it.
I couldnt hear mine...... and then one day it broke.
good insurance.
A.j.
PostPosted: Wed Oct 07, 2009 4:37 pm
It certainly sounds like a chain....like a chain rubbing on metal or the way a roller chain sounds when moving except louder. It's audible enough that you can hear it with the hood closed if you put your ear up to the grille of the truck. Under the hood, it seems to be coming from the front of the engine. Seems like a chain problem to me.
PostPosted: Thu Oct 08, 2009 12:23 am
my 76 has no such noise.you can barely hear it running cept' for the exhaust.
76 mikado project,mean green
PostPosted: Thu Oct 08, 2009 6:10 pm
Took off the tappet cover tonight. Chain is tight as can be and from what I could see the tensioner and guides looked pristine. However, I can do the old 2x4 stethoscope trick and the noise is very definitely coming from behind the lower part of the timing cover. Going to order the timing kit tomorrow and replace the timing set, water pump, and gaskets.
PostPosted: Thu Oct 08, 2009 7:39 pm
I hope that fixes your problem. Keep us posted and let us know what you find. Good luck fixing your Luv.
1981 Luv 2WD
1981 Luv parts trk
PostPosted: Thu Oct 08, 2009 9:21 pm
DO NOT wait to check it out.. If the chain breaks you can say by by to most of your valves. I have lost intake and exhaust valves both. I had a problem with the chain, replaced the chain, and lost the tension adjuster and it happened again.... Replace it all when you do!!!!!!!! Not real smart on my part.
PostPosted: Thu Oct 08, 2009 11:14 pm
Yeah...I'm going to replace everything when I'm in there. The whole kit is only $60, so you're foolish not to. Oil pan, tappet cover, and timing cover gaskets will get replaced as well, along with the water pump. Hopefully that will fix the problem.
PostPosted: Fri Oct 09, 2009 6:16 pm
Picked up a real stethoscope tonight. Holy racket on lower right side of timing cover (quiet on left side), especially as RPMs increase (not as audible without stethoscope, assuming that's from fan/exhaust noise) I'm guessing the lower part of the guide is bad. Ordered all the parts tonight, be here towards the end of next week.
Users browsing this forum: Bing [Bot] and 28 guests
